Hi friends
I would like to ask how to find out the maximum amount of RAM supported by my PC. How do I know about it???
I have a: P-4 845 GEBV2 Motherboard with onboard graphics.
.dk
Why not visit the Mobo manufacturer's website, see the online user manual and you can be very much sure about the RAM supported. Also you can save it for future guidance.
P-4 845 GEBV2 Motherboard supports a maximum of 2GB RAM. However it is advisable that if your old RAM is 256MB then you should try to purchase another 256MB. If they are not matched your PC will not run and your vendor may refuse to change it.
