Old 08-11-2004, 10:10 PM   #1 (permalink)
Default confused...kindly help!!!
dear all,
my C: has a capacity of abt 5.41 GB.....all the files an folders (incl windows and programs files) come to abt 4.0 GB or so, but the free space available on the disk is only 250 MB...
there is no paging file specified on C: (none of the drives infact)
i performed a virus scan on the C: , but there are no viruses(McAfee)
i have the windows XP SP2 installed on my system
i have connected another 20 GB drive to my conp on the same IDE...
wat cud be the problem....
baasha is offline
Old 08-11-2004, 10:56 PM   #2 (permalink)
gxsaurav
Posts: n/a
There has to be paging file, even if U don't know about it
Old 08-11-2004, 11:17 PM   #3 (permalink)
King of my own Castle
freshseasons's Avatar
Try searching pagefile.sys using show hiddenfiles and Os files option.
freshseasons is offline
Old 09-11-2004, 12:04 AM   #4 (permalink)
guys,
wat i meant is tht i have not allocated any space on my C: for virtual memory
the total paging file for C: is 0 MB
baasha is offline
Old 09-11-2004, 02:02 AM   #5 (permalink)
Did you count the System Volume Information folder ?
pimpom is offline
Old 09-11-2004, 02:07 AM   #6 (permalink)
Check under the folder Documents and Settings\<User Name>\Local Settings\Temp
Most probably its the culprit!
sailendra is offline
Old 09-11-2004, 02:34 AM   #7 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
man!................ i think it's SYSTEM RESTORE DATA...
in C:\System Volme Information which is by default "not accessible"
remove SYSTEM RESTORE DATA by diskclean up.... then click on "delete restore points" on bottom...
or if u don't need it.... just disable it...........
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 09-11-2004, 08:49 PM   #8 (permalink)
Let the music play.....
djmykey's Avatar
Ya but still having tried all of ur trick i still can see that some of my space is being eaten by someone.
djmykey is offline
Old 09-11-2004, 11:01 PM   #9 (permalink)
I am not sure...
But try running a physical scan on your disk, may be (I mean MAY BE) your drive is facing a physical hardware problems.
Just check the size of the partition, by viewing the partition details using the FDISK (Please use the FDISK very very carefully).
Or try running the Norton Sytem Works.
Also Please try disconnecting the second HDD and check the partition size.
Before all these, please back up the files which you think are important, to another partition or may be another harddisk.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 10-11-2004, 01:51 PM   #10 (permalink)
I would prefer that u install the application that u use (not the standerd ones that windows install) in another partition. That will reduse some space , and u will get some space for defining paging file.
[url]http://gameunion.forumer.com[/url]
[url]http://sumanpaul.modblog.com[/url]
sumanpaul is offline
Old 10-11-2004, 10:03 PM   #11 (permalink)
shekar u were right, system restore was indeed the culprit, but only partly(i kind believe i missed tht)....i'm still 500 MB short...
capacity : 5.14 GB
size on disk : 3.84 GB
free space : 804 MB
i'm short by 1/2 a GB...is this normal...i have turned off system monitoring now...
the second HDD is disconnected...
any other sugeestions please ??
thanks for the help soo far...
baasha is offline
Old 10-11-2004, 10:05 PM   #12 (permalink)
Just try out!
goto iolo.com download system mechanic from there.scan for duplicate files .also scan for junk files enable t he option prefect folder here. scan delete the files.also goto to disk cleanup delete the restore point except the latest.
And tell how much did u recover.
Satyajit Tambe
archzillanx is offline
Old 12-11-2004, 12:27 AM   #13 (permalink)
If you are using NTFS file system then its the cause. NTFS file system occupies some space on drives to store respective drive information.
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 13-11-2004, 10:15 PM   #14 (permalink)
my C: is FAT32
arch, i dloded the sys mech...there indeed are a lot of duplicate files...is it safe to delete all those files...some are XP sp2 files as well....they are exact copies...
baasha is offline
- by Krow
