Old 14-04-2006, 12:59 AM   #1 (permalink)
Default How to compress files??
Hello all u people recently i downloded a software tha was 50mb when i unrared it usingwinrar i got 2 zip files containig parts of software. When i unzipped them i got a 150mb .iso file. I wanna ask can i aslo hav compression ratio of 3:1 for 1gb or more large data using winrar and how??Give me a tutorial kind of u can!!
malhotra.priyam is offline
Old 14-04-2006, 01:50 PM   #2 (permalink)
It all depends on what kind of data you wish to compress. Some files just don't have enough scope for compression.
You could also try the 7z format available in 7-Zip.
kundra.nitin is offline
Old 14-04-2006, 03:11 PM   #3 (permalink)
There is also a Uharc compressor , google for it for more info . DOnt know much about it but it compresses data to large extents
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 14-04-2006, 03:11 PM   #4 (permalink)
sknowonweb's Avatar
Ya data compression is maximum while picture movie compression is too minimum.
SO compress ur text /code files separately to yield maximum efficiency.
In a Linux CD ISO file knoppix of 700MB contains a 2GB size worth of softwares compressed in it.
sknowonweb is offline
Old 16-04-2006, 03:48 PM   #5 (permalink)
try kgb
sanju is offline
Old 16-04-2006, 11:44 PM   #6 (permalink)
shoegoe's Avatar
Compression depends on the type of data being compressed. it is possible to compress a 3gb file into 50kb.. that is if the file contains nothing but a 3 gb allocation without data..
I think there are old threads regarding these 50kbto3gb files. they are called bombers i think..
And most of text data..like a .txt .doc file can be compressed to high degrees as they contain repitition of similar characters..
I prefer .rar to .zip as the former is wide spread in distribution. You can see mostly .rar files in all distribtution sites..
in winrar, there is an option to compress to a maximum extent. it just takes hell a lot of time to compress some more..
7-Zip and Uharc are also very good. especially uharc has high compression ratios. this may be due to high compression algorithms.. But ..you cant compress certain data beyond its normal extent inspite you use better compressors..
Hope it helps
shoegoe is offline
- by Krow
