Old 08-11-2004, 06:06 PM   #1 (permalink)
Default Hard disk problem
hi,
I've a 40 GB hard disk in which only windows xp & applications are installed which should not take more than 4-5 GB of space but it is showing the opposite. around 5 GB is free & 32 GB is used space
I've tried defragmentation but not successful.
What could be the problem?
regards, rohit
rohitsahib is offline
Old 08-11-2004, 06:35 PM   #2 (permalink)
vysakh's Avatar
the system volume information takes a lot of space. it increases each time u make a change
if u format it it will be gone
Incompatible message format
vysakh is offline
Old 08-11-2004, 06:48 PM   #3 (permalink)
I formated the hard disk few weeks back & i don't think that it should take so much space.
Old 08-11-2004, 06:59 PM   #4 (permalink)
vysakh's Avatar
it takes a lot of space
when a diskchecking happens(while booting) new folders are formed like found000 found001 etc
they to take a lot of space
how big is ur windows folder (c:\windows)
vysakh is offline
Old 08-11-2004, 07:05 PM   #5 (permalink)
try disk cleanup it might free some space for you
[digitt] is offline
Old 08-11-2004, 07:10 PM   #6 (permalink)
c:\windows is only 1.5 GB
But C:\Documents and Settings\Rohit\Local Settings is around 26 GB
Old 08-11-2004, 07:14 PM   #7 (permalink)
C:\Documents and Settings\Rohit\Local Settings\Temp
is the problem. It is around 26 GB. MY God!
Old 08-11-2004, 07:17 PM   #8 (permalink)
vysakh's Avatar
i have a game cd of delta force black hawk down
its size--686 MB
in it there is a folder DFBHD
its size--4.1 GB
may be ur system is showing an error
vysakh is offline
Old 08-11-2004, 07:18 PM   #9 (permalink)
But disk cleanup doesn't show this temp folder
Old 08-11-2004, 07:22 PM   #10 (permalink)
vysakh's Avatar
its okay to delete the files of temp,history & temp IE files
vysakh is offline
Old 08-11-2004, 07:26 PM   #11 (permalink)
gxsaurav
Posts: n/a
Simply delete all the files in the folder
c:\docs!settings\your user\local settings\temp
Old 08-11-2004, 07:30 PM   #12 (permalink)
yes, i know that vysakh & gxsaurav
I'm doing that for years. ; - )
But still sometimes, dumbness happens...LOL
Old 08-11-2004, 07:34 PM   #13 (permalink)
windows xp creates restore points which also takes up lots of space....
to delete them just go to the second tab on disk cleanup(sorry don remember the name). it wil delete all points exypt the last one..
my frnd freed abt 1.5gb yest by cleanup and deleting restore points
[digitt] is offline
Old 08-11-2004, 07:35 PM   #14 (permalink)
vysakh's Avatar
whats the size of c:\windows and c:\program files and c:\documents and settings
vysakh is offline
Old 08-11-2004, 07:52 PM   #15 (permalink)
hey guys, the problem is solved!
I told u that the temp folder was full & it's my dumbness that i didn't look there
thanks anyway!
rohit
- by Krow
