hey guys
i had installed same tnt2 card which had 32mb but still my xp and me were showing 16mb i.e.same problemas mentioned above.
then i installed apollo 3dthrill 128mb card running with sis315pro proessor
for this card also it was showing half the memoryi.e. it was showing 64mb only.then i istalled latest driver for card from apllo then system started showing 128mb
then i ran spybot S & D to clearup startup entries there i found same
Rscmpt.exe.
Spybot says it is an 64mb memory emulator used by graphic card.Full desription is
Current filename:
D:\WINDOWS\System32\Rscmpt.exe
Database status:
Necessity depends on users preferences
Value:
Rscmpt
Filename:
rscmpt.exe
Description
Required on the GeFroce 64 meg MX card to show the full 64 meg memory and appears to be a software memory emulator running under the Win2K - see _here_. High CPU useage results - hence the U status
Source:
Paul Collins Startup list
link given by spybot for more info is not working
http://www.guru3d.com/comments.php?category=1&id=67
so guys is graphic card companies cheating us?
and does really such emulators improve perfomance?
if not then they are cheating us.
And it was all from offical drivers!!!!!!!
