Old 11-04-2006, 09:00 AM   #1 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
Default Keep A Constant Speed...
well guys, i have a 256KBps connection. Whn evr im downloadin nethin, the download starts from (~)256 KBps and ultimately drops to (~) 50-60 KBps. Nw is there ne way by which i can keep the speed constant??? i mean atlesat get speedz of more than 100 KBps???
aku is offline
Old 11-04-2006, 09:29 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yes, when you start a d/l speeds drop from a high rate. Actually if you check closely that happens only for a second and the speed drops instantly to normal speeds, only the number falls down slowly. There is no way you can harness that unless you opt to go for a higher speed connection. You can try d/l managers for some extra 2-5 KBps edge perhaps...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-04-2006, 10:02 AM   #3 (permalink)
ashfame's Avatar
You may not be having a dedicated connection, that is why when more people are online i.e. more traffic, it gives less speed.
Try it once downloading a file @ night.
It might give u good speed.
Let me know whats the result
ashfame is offline
Old 12-04-2006, 12:50 AM   #4 (permalink)
aku
Gonna make it BiG
aku's Avatar
hmm.. not satisfactory
aku is offline
Old 12-04-2006, 01:36 AM   #5 (permalink)
Your Maker.
MysticHalo's Avatar
Broadband speeds r unaffected by time. ie . day or night ...or traffic unless u have a dedicated modem/router.
Its managed by the network remote server, and is constant for most of the time, unless the server is down or something.
thats startoff- speed is just instantaneous. If u get 50-60 kbps normal dwloading speed, its good, perhaps u have a 512 kbps connection...the best available for a home user.
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 12-04-2006, 03:16 AM   #6 (permalink)
mayanksharma's Avatar
Yeah! if you are getting 50-60 kbps speed at constant then you should have a connection of atleast 512KBPs speed. This downloading rate is not possible on 256KBPs connections.
And regarding maintaining constant speeds, what do you notice your speed in torrents??
Have you tried tweaking Firefox, your web browser?
and increasing your TCP/IP connections??
mayanksharma is offline
Old 12-04-2006, 11:57 AM   #7 (permalink)
Hi
First I want to tell you whenever U tried to download any file fm the web, It start in kB/sec not in kb/sec , that's why we multiplied with 8.
That's 8 kB/sec = 64 kbits/sec. (1 Byte= 8 bits)
Bandwidth is divided into two channels Upstream & downstream, Up-means u are uploading(sending info on to the server), dn- means u r downloading.
This is right when you treid to d/l any file fm the transfer rate goes high after that it goes dn bcz in that case both channels are utilized then after that it becomes constant ( if u hv dedicated connection).
One thing more d/l is also depend upon the file size, heavy file size would give you less transfer rate.
So enjoy ISP mathematics ....
Him007
Him007 is offline
Old 14-04-2006, 08:24 AM   #8 (permalink)
i have read on this forum only............
that a guy has 256kbps net connection..........
but surprisingly he gets download speed of 1 MBps.....
so i think u r bit unlucky.............
dharmeshhtailor is offline
Old 18-04-2006, 03:13 AM   #9 (permalink)
TechGuru#1's Avatar
Now,I think dharmesh.......atleaset.YOU hav beaten all others in ur "WISE BELIEFS"
TechGuru#1 is offline
- by Krow
