Old 11-04-2006, 08:36 AM   #1 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Default Java execution error!!
I have been writing simple java console programs since a long time. Now when I started workig in my dad's laptop , i am unable to execute the programs.
After successful compilation an error flashes---
Exception in thread "main" java.lang.noClassDefFounderror :file name
WHY IS THIS ERROR CAUSED ?? HOW TO TROUBLESHOOT IT??
nitish_mythology is offline
Old 11-04-2006, 09:13 AM   #2 (permalink)
See http://www.jguru.com/faq/view.jsp?EID=455768
It means that your classpath is not set correctly. Make sure your JAVA_HOME is set up right before you run the tomcat or startup scripts. More links available at above site
Arun
sakumar79 is offline
Old 11-04-2006, 09:31 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
This also happens if you make a mistake in the proggie's class and filenames...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-04-2006, 01:29 PM   #4 (permalink)
OSS Enthusiast!
Default Thanks JGURU...
@JGuru---
Thnks for your P.M. I thought you will be busy and it will take you some time to reply, hence I posted the topic on forum.
- by Krow
