11-04-2006, 07:30 AM
any way of permanent replacement of IE ???
hi guys ,
i had a question to ask ?? can't we just replace IE from our windows xp by opera or firefox fully , i mean can't i just remove IE from my xp forever and replace all it's activities with something good like opera or firefox ???
looking forward for your help ????
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
11-04-2006, 07:33 AM
Wandering in the zone ...
You can set Firefox or Opera as the default browser.Just right click on Taskbar,click Properties,select Start Menu and then Customize.Then select Mozilla Firefox as the default browser.
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
11-04-2006, 07:42 AM
Commander in Chief
You can disable rights to run IE by going to
Start > Program Access/Defaults > Custom > Choose a default web browser > Select Fx/Opera and deselct the check box next to the IE option "Enable access to this program"
Harsh J
www.harshj.com
11-04-2006, 08:03 AM
no it doesn't work what i really wanna ask it i want IE out of my system and instead want firfox / opera , in that way that even if i open my computer it comes not in IE but firefox and IE get's uninstalled for ever .
IS THIS POSSIBLE ????
11-04-2006, 09:13 AM
no microsoft's IE can't b removed tht way too !!!
would try to use nlite !!!!
11-04-2006, 09:19 AM
Commander in Chief
Its not advisable to wipe off IE from your system since its integrated to the OS's works like Help files and etc... So I wont recommend doing something like that... better jus cover it up and hide it... and may I ask the reason of doing so? Are you such-a-huge fanboy of browsers like F/O or what?
11-04-2006, 09:48 AM
@ qwety maniac :: ya something like that u may say , or the other way i can say i m bored of seeing windows explorer IE windows everytime i open my mycomputer !!!!!
and once long before in complete reference of windows 98 i had a glimpse of this type of thing in which the author described a way of replacing IE completely to NETSCAPE !!! uninstalling the IE completely !!!
but can't get that book now !!! sad !!!!
so i asked it here !!!
11-04-2006, 07:01 PM
There is one version of XP (heavily modded of course) called "Tiny XP" which EXCLUDES IE and the installer is less than 150MB!!! I tested it and it runs XP (integrated SP2 with updates) with 50MB mem only!!!!!! And its so nice and fast. Some of u may try it if u like. Just try google for more info.
11-04-2006, 07:39 PM
Microsoft MVP
U can try XPLite to remove the Internet Explorer completely from Windows!
U can also remove many unusable components using this tool...
And Yes! The edition suggested by Pooja also works well, though I hvnt used it but hv heard a lot about it...
11-04-2006, 07:43 PM
Commander in Chief
Does that TinyXP have drivers in them? Coz I dont wanna mess up drivers
Harsh J
www.harshj.com
11-04-2006, 07:46 PM
I am Optimus Prime
TinyXP can induce problems in PCs as has been reported! It is better to mod the XP directly! We can remove the softwares we do not need from Add/Remove Components and there is no use removing IE from the system! If you manage to remove it completely it would really mess your system up!
Its not good to use modded and illegal versions of XP! Please don't recommend it!
11-04-2006, 08:21 PM
Indian by heart
Illegal softwares should not be recommended. I second Navjot on that issue.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
11-04-2006, 10:38 PM
While I was using Win98, I removed IE comletely using a software and installed and used FF. I wrote about it in the forum but many people were not favoring it. But I did'nt face any problem other than pages that will open only in IE. Unfortunately, I forgot the name of the small SW but it ends in 'exterminator'.You may try google.
V.Prem Kumar
V.Prem Kumar
17-04-2006, 10:36 AM
@ janitha - plz. try to remeber the name of software and tell ??
17-04-2006, 11:03 AM
Why not simply instruct the firewall to deny network access to IE? Internally, lot of items run on IE engine... Even some third-party programs (especially those created using VB) can be trying to use IE to do certain stuff... So, not sure if it is good idea to remove IE...
Arun
17-04-2006, 01:22 PM
I belive there's no way to completely un-install Internet Explorer.
It shares many files with the rest of the OS.
You can remove IE icons and shortcuts:
Alternate Method
1. Insert the XP CD-ROM.
2. Click "Install Optional Windows components".
3. Un-check the box for Internet Explorer.
4. Click Next.
Then delete the IE folder,but you have to somehow disassociate it with other programs which might need it sometime.
25-04-2006, 09:26 PM
Yes, it is "ie eradicator" and you can find the download link by googling. But mind you, it will work only with older versions like Win98.
V.Prem Kumar
Search this Thread |
