Old 08-11-2004, 02:02 PM   #1 (permalink)
Default Hibernation problem
hi,
My OS is winxp Pro. Processor P4 2.4 Ghz, 1 GB 400 Mhz DDR SDRAM, 128 MB geforce 4 graphic card, 2 hard disks (40 & 80 GB )
I had 512 MB ram than i installed 512 MB more but after that i always got the error ' Low memory api ' whenever i tried using hibernate feature.
Few days back, i formated my c: than after reisntalling windows xp pro, i could hibernate but not always. Many times, i receive the error ' low memory api '
What could be the reason? And how to get rid of it?
thanks guys,
rohit
rohitsahib is offline
Old 08-11-2004, 02:21 PM   #2 (permalink)
sms_solver's Avatar
you didn't mentioned the MB type
if you are using i865 chipset based motherboard, then you better use the
RAM in dual channel mode.
do mention the MB type and name
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 08-11-2004, 02:53 PM   #3 (permalink)
oops!
MY motherboard is inter original 865 GBF.
how u switch to ' dual channel mode ' ?
thanks!
rohit
Old 08-11-2004, 05:46 PM   #4 (permalink)
hmmm
i dun think its a dual channel problem
anyways for dual channel u need
a mobo supporting dual channel memory performance
2 memory modules of same capacity same build ... exact same i mean
then u need to install it in the dimm slots with the same color which are usually alternate ...
and i think dual channel is automatically activated ... or at most in some mobos u have to enable it from bios ..
and thats it ...
maybe the problem is ur runnin it in dual channel and u dunno it .. and that the memory modules dont match !!!
try installin one module ( preferably the new one since thats what seems to cause the trouble ) into another slot and check again
do let us know .
No Mercy, No Limits.
theraven is offline
Old 08-11-2004, 06:53 PM   #5 (permalink)
these r both kingston 512 mb 400 mhz ddr sdram
dimm slots with same colors? where are the colors, man? ; - )
Old 08-11-2004, 09:56 PM   #6 (permalink)
usually mobos with dual channel have 4 dimm slots
2 will be say ..black in color .. and 2 in blue ..
to support dual channel ur ram chips must both be in either the black ... or the blue
i hope u got that
anyways like i said ... try runnin the ram in a diff slot ... just in case
theraven is offline
Old 10-11-2004, 01:22 AM   #7 (permalink)
sms_solver's Avatar
Intel MB sp (865 and 875) don't have colored DIMM to help
in installing RAM in dual channel mode. Other new MB are colored
Assume these r yrs DIMMs
1 2 3 4
if you install your RAMs in
(1 and 3) or (2 and 4)
then your RAM will be in dual channel mode.
see D865 motherboard manual (PDF) for detail
[ॐ एसएमएस॰सोल्भर ॐ]
- by Krow
