Old 09-04-2006, 06:59 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Help with Alcohol 120% needed???
Hello friends!
I have Alcohol 120% installed in my system and the software has created "I" drive in my system. Now every time I start my computer, I have that I drive activated. How can I avoid Alcohol 120% from running atall or creating any drives till the time I dont need them?
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 09-04-2006, 07:55 PM   #2 (permalink)
U can open Alcohol 120% and under virtual drive..choose number of virtual drives=0
but u will have to change it to 1 every time u need to mount any image...
Maybe someone else has a better option...
If u think u r right...u r a bad thinker!
Jatin_T is offline
Old 10-04-2006, 11:29 AM   #3 (permalink)
parthbarot's Avatar
but y dont u acept that 1 drive as ur 'drive'?
i have one so...
keeping it doent create any probs yaar...
and no memory eating also...
bar bar usko hila mat yaar..
when u need to moount,just mount and..after use unmonut it...simple.
Parth.
www.techlads.com
Paarth.
parthbarot is offline
Old 10-04-2006, 01:26 PM   #4 (permalink)
Learner
Kniwor's Avatar
i always keep a virtual drive in my system....
infact that is one of the first few things i install in my system.....
deamon tools...
because i keep iso's of many games ond softwares on hdd and cant install them unless i have a virtual drive....
Kniwor is offline
Old 10-04-2006, 05:35 PM   #5 (permalink)
Go For Daemon Tools , it is smaller and much better . But you cant make images with it .
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 10-04-2006, 10:27 PM   #6 (permalink)
9437077259
go4saket's Avatar
I dont have a problem with keeping one drive active, but I just wanted to free some more sytem resource by switching it off completely...
Win 7 Ultimate
go4saket is offline
Old 10-04-2006, 11:57 PM   #7 (permalink)
::vicky::'s Avatar
reinstalling the software may help
::vicky:: is offline
Old 11-04-2006, 08:14 PM   #8 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Just uncheck the option of mounting drives again on boot irrespective of the fact how many drives you selected! It will be loaded once and then after reboot will not load it!
Anyways since the release of Daemon Toolsd v4.0 - they made it very bad that version I found Alcohol as the only best virtual drive software!
navjotjsingh is offline
Old 11-04-2006, 08:44 PM   #9 (permalink)
Indian by heart
planetcall's Avatar
Navjot.....there are better alternatives to Alcohol. I personally feel PowerISO is the best Optical drive emulator. Also, its default format DAA is better than ISO, NRG, bin or the format of Alcohol. It supports password protection with encryption. It supports emulation for almost all known virtual image formats. I personally like it and use it to compress my iso images. The new version 3.0 is really good and very fast. It is better than compression softwares like rar or zip as well, though they have an entirely different purpose.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
- by Krow
