Old 07-11-2004, 04:54 PM   #1 (permalink)
Default urgent help needed
Dear Friends,
I bought a system with followinfg spec,
P4-2.4GHz FSB 533 MHz
Intel Motherboard 865GBF FSB supported 400MHz
DDR RAM simtronics 400MHz FSB.
Now I an getting a memory speed of only 333MHz. The seller says it is due to the processor which do not support 400MHz speed. While It hink that the RAM is not supporting . I think this RAM of simtronics brand has some problem .
Please help me as soon as possible becoz time is running out fast for me to make an exchange.
Thanks and regards,
Atul
striker_1909@yahoo.com
striker_1909 is offline
Old 07-11-2004, 07:14 PM   #2 (permalink)
865 GBF supports 400MHz ram .it also supports dual channel DDR.
i think u need a 800FSB processor to utilise DDR400 RAM properly.
nikhilesh is offline
Old 07-11-2004, 09:21 PM   #3 (permalink)
gxsaurav
Posts: n/a
He is rite, the 533 FSB CPU will not work with 400 MHz RAM, 865GBF revarts it back to DDR333
Old 08-11-2004, 01:24 AM   #4 (permalink)
sms_solver's Avatar
You have same config. like mine
The 400MHz RAM only works with processor with FSB 800 MHz
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 08-11-2004, 06:49 PM   #5 (permalink)
just a quick question here
i hav p4 1.7 ghz i m thinkin of upgrading my mobo(845 doesnt support ddr) possibly an 865....
planning to buy ddr ram as well ....
just wanna know which memory speed ram wud b compatible wid this processor
and whether dual channel ddr is compatible wid my processor
thanx in advance
[digitt] is offline
Old 08-11-2004, 07:08 PM   #6 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
gx is right........ it retrives it back 2 333
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 15-11-2004, 11:25 AM   #7 (permalink)
Default urgent
can bios upgradation solve this problem
waiting for reply
Old 15-11-2004, 11:54 AM   #8 (permalink)
no. It has nothing to do with bios. Your motherboard supports 400Mhz but your CPU is 533Mhz FSB which will at default settings will run your memory at 333Mhz.
You can still use dual channel mode though without any problems.
The only way to get ram working at 400Mhz with 533Mhz CPU is to overclock the CPU but nly do it if you know what you are gona do and it does involve its own risks.
C2D E6600 L626A195 @ 3.42Ghz 24x7|Asus P5N32-E SLI|Crucial Ballistix DDR2 1000|8600GT|4x320GB Hitachi|SBlive 24bit|OCZ Gamextreme 700Watt PSU|Ultra 120 Extreme|Viewsonic VX2025WM 20.1'' widescreen LCD
funkymonkey is offline
- by gohan89
