Old 07-11-2004, 10:44 AM   #1 (permalink)
Default Doom-III, System Req.
Dear Friends....
My sys config is:
P4 2.8HT/D865GBF intel mobo
GeForce4 MX/MMX440 64 MB AGP card
512MB DDR
Will Doom-III run smoothly on my sys or do i need to do some enhancements......BTW NFS-6 runs smoothly on my system....
Please advice me.....
Regards
Mark
mark is offline
Old 07-11-2004, 11:56 AM   #2 (permalink)
You can run Doom3 but it wont be smooth at high quality. You will have to turn-off some of the eye-candy & run the game at low or medium quality graphics to get a playable frame-rate. Upgrade your graphics accelerator if you want to run it smoothly at high quality. Also try running the demo included in this month's Digit DVD.
game_dev is offline
Old 07-11-2004, 06:47 PM   #3 (permalink)
vysakh's Avatar
wrong it will work fine.
it worked in mine on onboard graphics at high graphics settings with all eye candy things turned on
but surely dont expect to run in ultrahigh graphics mode
Incompatible message format
vysakh is offline
Old 07-11-2004, 08:11 PM   #4 (permalink)
it worked in mine on onboard graphics at high graphics settings with all eye candy things turned on [/quote
thats just not possible
at the most u mustve turned the eyecandy on but the gpu will just not support it
so despite of being activated ... u wont GET any eye candy
rather switch it off and get better frame rates than killin ur gpu
No Mercy, No Limits.
theraven is offline
- by gohan89
