Old 06-04-2006, 10:33 AM   #1 (permalink)
Default Free Download Manager 2.0 is released!!
Free Download Manager (FDM) is a full-featured download accelerator and manager. It is absolutely free! Using this software product you can easily download a list of files and whole web sites from any remote server via HTTP, HTTPS and FTP. With FDM the downloading process will be as easy as never before!
We are pleased to announce that the new 2.0 version of Free Download Manager has been released.
What's new in version 2.0 build 416:
[+] Order of downloads can be changed via up/down buttons now
[+] Export/import downloads via XML file
[+] Export history of downloads to HTML file
[+] Separate window for each download (optional)
[+] Restrain all downloads mode
[+] Archive extraction support
[+] Generation of description files for downloads
[+] Command line has been enhanced
[+] Tools | Shutdown when done option now allows selecting the type of shutdown
[+] Set the date of a downloaded file identical to the one specified on a server
[+] Double click on floating windows now restores/minimizes FDM
[+] Option not to save the logs of downloads
[+] Downloads can be imported to the specified group
[+] Ability to set groups' root folder
[+] Tray menu contains list of recent downloaded files
[+] Ability to change timeout for user confirmation for performance of some tasks
[+] HTML Spider: more flexibility for ignore list
[+] Active downloads info window shows speed of downloading
[+] Some other interface improvements
[+] More flexibility for creating batch downloads
[+] File integrity check. Supports MD5,SHA-1,SHA-2,CRC32 algorithms
[+] Status bar shows the total traffic usage and the total speed of downloading [*] Support for files bigger than 2 GB [*] Support of SIZE command by FTP server is not required now [*] Improved color indication of resume support
[-] Bug in downloading using FTP passive mode with some FTP servers
[-] Export downloads on the list didn't work
[-] Sometimes HTML Spider didn't download images
[-] FDM entered into an infinite loop if file name on a server contained invalid characters
[-] Conflict with Microsoft User Profile Hive Cleanup service
[-] Bug after deleting a mirror from list of mirrors
[-] Sorting of downloads worked incorrectly
[-] Some other bugfixes
New version of Free Download Manager is available in the Download section.
Site: http://www.freedownloadmanager.org/
Download: http://www.freedownloadmanager.org/download.htm
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
naveenchandran is offline
Old 06-04-2006, 10:43 AM   #2 (permalink)
nishant_nms's Avatar
Downloading it
nishant_nms is offline
Old 06-04-2006, 10:53 AM   #3 (permalink)
parthbarot's Avatar
good thing yaar....
like it...
www.techlads.com
Paarth.
parthbarot is offline
Old 06-04-2006, 11:06 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Nice. D/ling
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-04-2006, 07:27 PM   #5 (permalink)
nice interface now,,,,,,,
very perfect d manager now
mkmkmk is offline
Old 06-04-2006, 07:47 PM   #6 (permalink)
gooby pls
Third Eye's Avatar
DAP 8 is the best !
Free Download Manager 2.0 Sucks !
Third Eye is offline
Old 06-04-2006, 09:35 PM   #7 (permalink)
dIgItaL_BrAt's Avatar
Thnx
Downloading it.
dIgItaL_BrAt is offline
Old 06-04-2006, 11:23 PM   #8 (permalink)
chinmay's Avatar
Originally Posted by tech_mastermind
DAP 8 is the best !
Refrain from worthless trolling in an otherwise clean Software update thread. You don't expect people to change their opinion and defaults by an unreasonable rant. Do You? Download Accelerator Plus for that matter has been certified as infected with adwares and the adware free version comes for a price contrary to FDM which is totally free and performs its function well.
Thanks for the heads up naveenchandran .
chinmay is offline
Old 08-04-2006, 08:30 AM   #9 (permalink)
The pWnster
Vyasram's Avatar
i am a idm(pirated) user, i wanna shift to a legal free one like fdm. does fdm have all the features of idm, what're the diffs
Sigs suck
Vyasram is offline
Old 08-04-2006, 08:33 AM   #10 (permalink)
The pWnster
Vyasram's Avatar
DAP 8 is the best !
Dap 8 , best?????
Not even close. Adware, hogger, unwanted eyecandies,.
And i strongly oppose if anyone disrespects a free alternative for a paid software . Think abt the ppl who cant afford Dap 8
Sigs suck
Vyasram is offline
Old 08-04-2006, 11:52 AM   #11 (permalink)
LegendKiller's Avatar
See,fdm is the best now...
with all the added features i dont think there's any need for any paid download manager....
Fdm does the job as good as any paid one..so why waste bucks???
However getright might do well other than fdm,simply because of its bittorrent downloading capability....
The getright-6 version which is beta stage is doing very well with my bittorrent downloads...
u may try: getright.invisionzone.com...thats their forum...
LegendKiller is offline
Old 16-04-2006, 02:41 AM   #12 (permalink)
mobilegeek's Avatar
Free Download Manager 2.0 is released -- Great
FDM is an indispensable tool for download acceleration. It splits files into several sections and then downloads them simultaneously allowing you to increase your download speed up to 600%.
This software application can be used in automatic mode. You can schedule the following operations: set or hang up the Internet connection, exit from the program and shutdown the computer. All the operations mentioned above can be set at the specified time.
FDM allows adjusting traffic usage. So it provides you with an opportunity to browse web pages much faster if you use a low connection speed.
System requirements:
* Microsoft Windows 9x/ME/NT/2000/XP
* IE5.0 and above or better FireFox or Opera 6x - 9x
Direct Download: http://files.freedownloadmanager.org/fdminst.exe
FDM ver. 2.0 (1583 Kb, setup)
mobilegeek is offline
- by gohan89
