recently while trying to download\upgrade a software for which iam paying annual fees an error appeared as above.then i wrote to their system administrator pointing the same. they advised me to check your browser setting.
i am using win xp sp2\i.e 6
can somebody help?is it got something to do with java?
For IE browser, go to Tools->Interner Options->
Advanced (tab) and check the checkbox 'Use JRE 1.5.0
for <applet>. Click Ok and restart the browser.
First of all check whether you have installed JRE!!
If not download and install it from http://java.sun.com
