Old 06-04-2006, 12:17 AM   #1 (permalink)
Default Computer shows blue Screen
My computer is Athlon Sempron with 256 MB RAM. I'm using PCI Smartlink 56K Voice Modem.
Often (Mostly when connected to the internet) i get BSD, which says
the computer have been halted to prevent damage (not sure of this part)
.......................... select safe mode.
Technical Information
** STOP : 0x000000D1
(0xFC3BFB75, 0X00000009, 0X00000000, 0XF9A8614B
ptserial.sys - Address F9A8614B BASE AT f9a6500, dATESTAMP 2e25eb9f
Can this be due to a corrupt modem driver or a hardware failure
valtea is offline
Old 06-04-2006, 06:22 AM   #2 (permalink)
PTSERIAL.sys has to do with the modem. It suggests that you are running a pctel micromodem - you could try updated drivers for it.
Arun
sakumar79 is offline
Old 06-04-2006, 11:29 AM   #3 (permalink)
ok. I have downloaded the latest driver from
http://www.smlink.com/content.aspx?id=147
I will post again and tell if this solved my problem
valtea is offline
- by gohan89
