05-04-2006, 07:04 PM
My 256KBPS Speed test
Hey I have 256KBPS Sify broadband connection. I have gone through a speed test on this site http://www.speakeasy.net/speedtest/ and the NEW YORK CITY SERVER. I have the following results. I not satisfied with the upload speed.
05-04-2006, 07:23 PM
but at least it should be above 128 KBPS.. Is there a tweak for it....
05-04-2006, 07:39 PM
gooby pls
i got this,mine is also 256Kbsp DSL connection.i dont think so this is my real speed.
05-04-2006, 07:48 PM
Hey wht was ur server
05-04-2006, 08:06 PM
Pharmaguru
i got 259 kbps download and 60kbpas on same server as you but on Bsnl 256kbps broadband
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
05-04-2006, 08:16 PM
In Pursuit of "Happyness"
Airtel gives almost similar upload speed too.. Im on 128 kbps connection..
Last Result:
Download Speed: 105 kbps (13.1 KB/sec transfer rate)
Upload Speed: 101 kbps (12.6 KB/sec transfer rate)
And dont ever expect good uploads on sify..
05-04-2006, 08:43 PM
huh  ..... why man....... :roll:
05-04-2006, 08:53 PM
Im on Tata Indicom Broadband, Connection speed as per Connection Details is 544 kbps... Though tariff plan says 256 kbps...
I typically get about 210 kbps down and 180 kbps up... I think it is pretty good...
Most sites load pretty fast... Today, I was downloading some brochures from a US website, I had about 5 simultaneous downloads and I was hitting about 25 KBps regularly...
Only gripe is this forum often takes forever to load... Most other sites I visit load fast... Not sure if it is traffic or something else...
Arun
05-04-2006, 09:03 PM
Cuz i had sify's 128 kbps connection earlier and i rarely got upload speeds of 2-3 KBps. When i asked customer care about it, they said the rated speed is only for download. Upload speeds are not guarenteed in any way..
05-04-2006, 09:08 PM
231 D/l speed and
147 Upload speed
on the MTNL Triband
05-04-2006, 09:14 PM
agree with kalpik,
the u/l and d/l speeds on airtel are almost the same.
05-04-2006, 09:39 PM
Actually i get more upload speed then download speed
05-04-2006, 10:27 PM
Oh!!! now I understand Sify SUCKSSS!!!!!...... I have renewed by connection nearly after 4 months... 'cause of my boards exams.......when I said to renew they renewed after 2 days and also I found tht someone has cutted the internet CABLE wire.. When asked about this they said tht they r not responsible for it.....moreover they took Rs.300 from me and introduced a new wire... This such a mess........Also when surfing the internet it always stuck in between.....Most of the problems I face r...."The Local Area Network is Unplugged" and "There was problem when connecting Sify server".........
Secondly it is my mistake... I should have not renewed my account......
05-04-2006, 10:38 PM
Hey after visiting www.speedguide.com and performing speed test at http://howfastami.com.......I get the following results but the only problem is my UPLOAD speed
05-04-2006, 10:47 PM
I am on sify and when using torrents I get speed from 35 to 44 KBps
05-04-2006, 10:53 PM
urs still pretty decent look at mine!!
and i have a 256kbps connection
05-04-2006, 11:00 PM
Commander in Chief
Whoa! thats real crazy connection!
Co-incidentally, mine is the opposite of yrs
Harsh J
www.harshj.com
06-04-2006, 10:05 AM
the upload/ download speed may vary at an time instance. One may be higher than the other at that secong when the calculation is going on.
BTW, the isps usually provide lower upload speed than download.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
06-04-2006, 01:38 PM
#19 (permalink)
and under extraordinary circumstances only the upload wud be 2.5 times more.  and which i successfully manage to obtain it.
"Try again, fail again, fail better" - Samuel Beckett
06-04-2006, 01:44 PM
#20 (permalink)
gooby pls
hello
MTNL BroadBand
07-04-2006, 01:05 AM
#21 (permalink)
C.A.
Download Speed: 240 kbps (30 KB/sec transfer rate)
Upload Speed: 148 kbps (18.5 KB/sec transfer rate)
me too MTNL Broadband
07-04-2006, 09:40 AM
#22 (permalink)
GaurishSharma.com
see this ! !
what a ****
i can't belive it.i tried couple of times but no help.
i choose the new york server on firefox.
what to do?
i have bsnl dataone HOME 250.
08-04-2006, 07:16 PM
#23 (permalink)
I use 512 from BSNL and i got 544knps - download and 128kbps-upload
02-07-2006, 12:42 PM
#24 (permalink)
Re: My 256KBPS Speed test
I use BSNL Dataone UL900
Download Speed: 392 kbps (49 KB/sec transfer rate)
Upload Speed: 57 kbps (7.1 KB/sec transfer rate)
lol
DON'T YOU DARE CLICK THIS : http://kevan.org/brain.cgi?the.unforgiven
02-07-2006, 12:55 PM
#25 (permalink)
The upload & download speeds vary. Also your download from a particular Server
depends on several factors like how many users are connected to that Server,
How many simulatanous connections the Server can serve without compromising
speed, If too many users connect to a Server, than what it can handle it will crash!,
If there is a Server-overload your download speed will definitely decrease!!
Always download from the Server when it's not busy, you can get higher download
speeds, for eg., if you connect to a Server in the US connect & download in the
morning (our time) since it's night in the US , the traffic to the Server will be less.
02-07-2006, 01:25 PM
#26 (permalink)
Hey...
I got 181 Download Speed and
51 Upload Speed
Im on Hathway 256 Connection....
How is it ? tried the test twice
02-07-2006, 03:10 PM
#27 (permalink)
Actually, when i opt for a 256 kbps connection, then is amy reserved bandwidth equal to 256 kbps down+64kbps up or is it only 256 kbps down and the upload speeds r a bonus ?
~"Computers are useless. They can only give you answers."~
02-07-2006, 03:28 PM
#28 (permalink)
Last Result:
Download Speed: 474 kbps (59.3 KB/sec transfer rate)
Upload Speed: 257 kbps (32.1 KB/sec transfer rate)
I have MTNL_Unltd conn of 256bps
I am getting more thn promised
Formula: E=mc^2
Where,
E = Education M = money C = Caste
www.truegeek.coz.in
02-07-2006, 04:47 PM
#29 (permalink)
GaurishSharma.com
tested again now i got
d/l 300kbps(i am leecher
u/l 44kbps(seeding isn't my job)
i have dataone home 250
02-07-2006, 07:26 PM
#30 (permalink)
I have BSNL Broadband and my upload and download speed both are very good.
Regards,
Shovik.
Search this Thread |
