Old 15-07-2004, 08:45 AM   #1 (permalink)
Posts: n/a
Default How can i.............?
how can I make one shortcut that launch 2 or more programs at a time ?
plz help me!
Old 15-07-2004, 10:18 AM   #2 (permalink)
Simple use a batch file. Open Notepad and type something like below:
start C:\windows\calc.exe
start winword
Save the above two lines as a text file with extension .bat. Now right click the file in explorer and point to Send To-> Desktop (create shortcut).
You are done!. Just replace the above lines with paths to the programs you wish to launch. If the program is in the path you can just type the .exe file name. Otherwise, you need to specify the full path.
sailendra is offline
Old 15-07-2004, 06:07 PM   #3 (permalink)
Ok. it is already solved.. but one thing .. yaar. your question title should be clear .. that what are u asking..
I thought .. .... ..
Anyway
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 16-07-2004, 12:11 AM   #4 (permalink)
Posts: n/a
Default tnx
thanx dude
Old 03-09-2004, 11:51 PM   #5 (permalink)
King of my own Castle
freshseasons's Avatar
yaaa looks more like Mystry than Problem !!!!!
freshseasons is offline
- by gohan89
