Old 02-04-2006, 01:54 AM   #1 (permalink)
Default Hard Disk problem and Bios update query
I recenly bought a Segate 160GB parallel ATA hdd. I have a Pentium III 1.05B GHz on 810e motherboard with 384 MB RAm. The problem is whenever the hdd is connected in any configuration[ie.- primary,secondary,master,slave] my PC slows down considerably. I use WinXP Pro+SP2 with all the latest updates. BIOS detects the disk size as 136GB.
Can a BIOS update fix this problem?
Also when the hdd is not connected my PC works just fine.
vutonium is offline
Old 02-04-2006, 02:01 AM   #2 (permalink)
Traceur
zegulas's Avatar
I think there maybe some physical damage to your HDD, which has caused bad sectors, try and run scan disk and see if you get bad sectors.
Parkour: A journey started by two & followed by many...
zegulas is online now
Old 02-04-2006, 05:16 AM   #3 (permalink)
Nothing is wrong with your HDD,
how many partitions are there on the disc??
any other HD connected ??
How many optical drives??
also as u urself know,perform BIOS update(carefull though,dont let power go down inbetween!!)
grinning_devil is offline
Old 02-04-2006, 11:00 AM   #4 (permalink)
Dont think there is a problem in you HDD . But if you are going to update the BIOS be very carful as a mistake can render your motherboard useless.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 03-04-2006, 10:52 PM   #5 (permalink)
mayanksharma's Avatar
yeah try flashing the bios.this might help.usually older motherboards donot support large capacities drives.hence updating the bios helps in most of the cases.
and be sure to make the 160GB as the primary disk and then partitioning to be done on NTFS only,if u r using windows 2000 or XP!
bye.
mayanksharma is offline
- by gohan89
