Old 01-04-2006, 08:35 PM   #1 (permalink)
Traceur
zegulas's Avatar
Default DVD Writting problem
Hi, I have recently bought a new LiteOn DVD writer, now the problem is that, I made a mulitisesion DVD using Nero Express ver.7 for my Game's steups, but some 500MB space was remaining, so I added some 234MB setups again to it and now I can only see the latest setups that I have burned, so where are the old files, one of my friend told me that while writting the DVD I may have choosed the wrong track or something.
Now how do I retrive the old files, is there any software for such purpose?
Parkour: A journey started by two & followed by many...
zegulas is online now
Old 01-04-2006, 09:04 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
I think you are able to see only the new session. Some softwares like PowerISO/ISO Buster help you see the previous sessions
Harsh J
www.harshj.com
QwertyManiac is offline
Old 02-04-2006, 12:55 AM   #3 (permalink)
Traceur
zegulas's Avatar
I have iso buster, but I dont know how to see previous sessions, could you please be more elaborative?
Old 02-04-2006, 06:31 AM   #4 (permalink)
nil_3's Avatar
If everything fails, try Recover4All Professional or any Data Recovery software. It will recover everything in your DVD though in RAW format. But it wil work for you.
nil_3 is offline
Old 02-04-2006, 08:14 PM   #5 (permalink)
when u use isobuister it'll show u 2 tracks on the cd
select the one u wanna view ... as simple as that
sometimes multisession discs have that problem
No Mercy, No Limits.
theraven is offline
Old 03-04-2006, 09:30 PM   #6 (permalink)
You should import the old track when you burn again on a Multisession disk.
Keep this in mind next time you burn.
hsnayvid is offline
Old 04-04-2006, 01:06 PM   #7 (permalink)
Traceur
zegulas's Avatar
Thanx all, I will try what you people have said and will tell you if it works for me.
Old 06-04-2006, 12:12 PM   #8 (permalink)
try nero multi mounter . install it ( u'll hav to read readme for doing this ) .
Now right click on drive ( after inserting disc ) go to properties. u'll see a tab called volumes ( and others like recording , autoplay ...) . select volumes . now select whichever u want ( of the volumes listed ) , u can see previous ones also..
TIP - to avoid this from happeneing from next time choose the last track ( alsways ) while doing multi session.
If u're using nero express , insert the disc , after drive has detected the disc then go to "make data disc ". previous info can be seen . in nero express if u rite the disc as multi session wihout first inserting the disc . this happens !!
sagargv is offline
- by gohan89
