Old 01-04-2006, 05:36 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default Read from scratched cd/dvd's
I have few scratched cd's and dvd's. I have used badcopy pro v3.80 build 1108 and cd/dvd recovery to recover .vob files from a scratched dvd. The s/w's can recover the files but K-Lite and WMP10 cannot render those files. How do i make the recovered .vob files work?
Suggest any other gud s/w. which can TRULY recover the files by making them work.
BadCopy and cd/dvd recovery r gud s/w. but they r not helping me at the moment
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 01-04-2006, 06:08 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
You can try playing those files in Video LAN Player. http://www.videolan.org/vlc
kalpik is offline
Old 03-04-2006, 11:32 AM   #3 (permalink)
!FREEWARES!
Akshay's Avatar
Hey thnx kalpik it worked! d files played properly.
What is the logic behind it? I have all possible drivers installed from K-Lite and WMP10. Even PowerDVD failed to play those files. How cud VLC play them without a prb?
MBP 13.3";
Akshay is offline
Old 03-04-2006, 01:56 PM   #4 (permalink)
VLC player is one of the best players to play dvd and vcd files or any video file for instance
cyrux is offline
Old 05-04-2006, 11:08 AM   #5 (permalink)
9437077259
go4saket's Avatar
Default Re: Read from scratched cd/dvd's
You said you could recover the vob files using some software called badcopy. I have a few DVD's that actually are not strached but when ever I try to copy them to my HDD, after a certain point, it gived a data copy error. Can to please tell me a way to copy these files and which software can help me in this.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 05-04-2006, 06:58 PM   #6 (permalink)
!FREEWARES!
Akshay's Avatar
I had the same prb. I cudnt copy files from DVD/CD. These s/w.'s provide option for recovering files in diff. modes and have not failed even once while recovering/copying files from cd/dvd (though .vob files cudnt b played).
U can use CD/DVD Recovery v1.x or BadCopy Pro v3.80 build 1108 (both r not freewares). There is one more gud s/w. ISOBuster or something like that. BlindRead is also another excellent s.w. Google for them or chk at http://www.1000apps.com or
http://www.soft32.com.
CD/DVD Recovery: http://www.regnow.com/softsell/visit...ts/cddvddr.exe
CD/DVD Recovery s/w. had come in one of the DIGIT cd/dvd. Its faster than BadCopy Pro.
MBP 13.3";
Akshay is offline
Old 06-04-2006, 01:30 AM   #7 (permalink)
mayanksharma's Avatar
Videolan uses the open source code development technique for its optimum working under the worst circumstances.More than that VLC uses the actual system modules to render video and audio streams.
mayanksharma is offline
Old 06-04-2006, 07:36 AM   #8 (permalink)
kalpik's Avatar
Huh?? What is this "open source code development technique"?? And how does VLC use it for "its optimum working under worst cirumstances"?? Man.. Its just open source and thats it.. There is no special "development technique" for open source software.. And just because its open source does not mean it has to be good.. (though VLC is excellent!)..
kalpik is offline
- by gohan89
