Old 01-04-2006, 08:29 AM   #1 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Default How to Schedule to Dial the connection??
How to Schedule to Dial connection in windowsXP default task scheduler??
I mean if I have a dial connection for Broadband
or even the normal dialup for GPRS in network setting
& I want to start every time I login to a particular Profile.
Putting the shortcut in Programes>Startup . Doesnt help!!!
Plz advise
rollcage is offline
Old 01-04-2006, 02:33 PM   #2 (permalink)
yrana2002's Avatar
Well, rollcage,
You can use the rasdial command & create a batch file for your dialup.
Then you can use it to schedule to run at a particular time.
There is a similar tutorial on how to do such a thing::
Schedule Dialup
Hope it helps...
Savvy
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 01-04-2006, 11:34 PM   #3 (permalink)
rollcage's Avatar
Thanks captain .. I didnt find it in search .. It worked
rollcage is offline
- by gohan89
