Old 31-03-2006, 05:02 PM   #1 (permalink)
sagar_coolx's Avatar
Default UNdeletable folder!!!!!????
while merging two partitions witm partition magic, it created a folder.as my pc hung up when the operation was going on ,i restarted and found that there was a folde named tvids,which i had specified.
bu now,nor can i open the folder or delete it. windows gives a message sayig:access denied!!!!
olso,its size is shown a 0 bytes., pls tell me...HOW CAN I DELETE IT??????
sagar_coolx is offline
Old 31-03-2006, 05:18 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
try the safe mode
Harsh J
www.harshj.com
QwertyManiac is offline
Old 31-03-2006, 06:33 PM   #3 (permalink)
dIgItaL_BrAt's Avatar
Use Unlocker to delete it.
dIgItaL_BrAt is offline
Old 31-03-2006, 06:43 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
sagar : same recent problm here. had used partitonmagic.
wholockeme/deletedoctor had not helped
safe mode did not help too
i too would like an answer !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 31-03-2006, 07:16 PM   #5 (permalink)
::vicky::'s Avatar
ur drive has corrupted use partiotion magic again
::vicky:: is offline
Old 31-03-2006, 08:18 PM   #6 (permalink)
and do what???
btw,unlocker worked .thanx.
Old 31-03-2006, 11:43 PM   #7 (permalink)
No problem
Old 01-04-2006, 05:55 PM   #8 (permalink)
!FREEWARES!
Akshay's Avatar
If unlocker does not work, try:
http://grubletrang.com/apps/FreeFile.zip - Freefile - unlock protected files and folders
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 01-04-2006, 06:07 PM   #9 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ He already said unlocker worked for him!
kalpik is offline
- by gohan89
