Old 06-11-2004, 06:26 AM   #1 (permalink)
Default A branded machicn help
Hello ,
A company is offering
Cel 2.4
Asus Mother board 845
256 mb RAM
17 inch moniter
80 GB HDD
300 watt cabinet
Speaker
in 20999/- with taxes
is this pricing & configuration is correct. :roll:
Thanks
Asif
Hello Friends
Download
Mozilla Hindi 1.7.2 , Firefox 1.0 Final & thunderzilla 0.7.1 from [url]www.digi-help.com[/url]
Thanks
The Home of Hindi Mozilla
AsifIqbal is offline
Old 06-11-2004, 06:46 AM   #2 (permalink)
I forget that this system comes with DVD+CDRW combo drive (samsung)
Hello Friends
Download
Thanks
Old 06-11-2004, 08:49 PM   #3 (permalink)
a branded machine always costs more than anassembled counterpart because the company offers support, warranty, et al. heck, u cld get a p4 spending the same dough, or an amd+gfx card.
bottom line:if u want exact price to performance ratio, go for an assembled machine. if u like peace of mind more than the machine u r buying, go for a branded machine as the dealer takes care of all your headaches
hope this helps, bye..
technomodel is offline
Old 07-11-2004, 12:34 AM   #4 (permalink)
Hi , Where r u staying . If not it a metro then i suggest u to just forgate about the dam Branded PC. Just make your won config and assemble that
Roy (U can belive or cam\'t but this is true, this is Royal)
Dipteshghoshroy is offline
Old 07-11-2004, 02:33 AM   #5 (permalink)
The answer to the branded vs assembled question depends on where and for whom. If you don't know much about computers and live in a city where the "branded" company has a firm base of operation, you can go for a branded machine. Otherwise, you can assemble it yourself or get a reputable local assembler to put it together for you. A good assembler will even give you a reasonable warranty.
As to whether the configuration is correct, it depends a lot on what you expect to do with it. You could spend a bit more and get a much better configuration, or you could even lower it and get a mchine that is perfectly adequate for your needs.
pimpom is offline
- by gohan89
