Old 14-07-2004, 01:06 PM   #1 (permalink)
Default HELP!!!!!!!! Spyware?????
pls help guys
whenever i connect to the net, an explorer window automatically opens and goes to the url something like rxbot.info.com/buzz.html and sometimes some adultbrowser2000.something... . also sometimes the ent just stops responding, whatever page i open, the moment i press enter, i get a msg "internet explorer could not open the search page", no matter what site it is. when i click ok, it says web page unavailable. and when i try to download anything, anything, with or without download accelerator, from IE or opera, it gives an error. also my norton antivirus has stopped functioning. It just doesn't start. I tried installing Spybot - Search & Destroy, and also Spyware Blaster, but spybot doesn't open and spywareblaster doesn't work without mozilla. pls help guys this is 2 much 4 me.
prajneet is offline
Old 14-07-2004, 01:35 PM   #2 (permalink)
Hi,
Your system is infected by Spywares. Download and run all of these:
  • Spybot S&D
  • Adaware
  • The Cleaner
  • Any good antivirus like Bitdefender/Norton etc
Don't forget to update each of thoes softwares before running. Google for the download links. All of them except the last one are freewares. After u have done it, if the problem is not solved then Download and run Hijackthis and post back the output
Subhro[/list]
subhro is offline
Old 14-07-2004, 03:34 PM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Please post your HijackThis Logfile ...
http://www.spywareinfo.com/~merijn/downloads.html
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 14-07-2004, 11:08 PM   #4 (permalink)
Hey
Use CTRL+ALT+DEL and close all except explore and systray. Then start spybot, it will open.
Life is like an icecream;
Enjoy it befor it melts.
Zamran!
never_trust_any_stranger is offline
Old 17-07-2004, 03:53 PM   #5 (permalink)
hijackthis doesnt work. When i start it an error message flashes for a sec and then nothing happens.i managed to get spyware doctor .Surprisingly it indicates downlad accelerator as the most dangerous spyware on the system but i couldnt find the spyware which redirects webpages to http://fetish.adultbouncer.com/hot.html.What should i do?
prajneet is offline
Old 18-07-2004, 12:39 AM   #6 (permalink)
Yeah ... Zam is right .. Close all except Explorer ..
Old 18-07-2004, 01:15 AM   #7 (permalink)
#/bin/sh's Avatar
You can get rid of spyware by using ad-aware from http://www.lavasoftusa.com/software/adaware/ or spybot http://download.com.com/3000-2144-10...age&tag=button
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 19-07-2004, 12:11 AM   #8 (permalink)
The latest spyware blaster v 3.2 now supports mozilla/firefox.you can download it from http://www.javacoolsoftware.com
But it would not help u much as it can pevent the installation of spywares but can't detect those who are already there.
make sure u try what Zam & Batty said above .
It_is_Andrew is offline
Old 20-07-2004, 08:45 PM   #9 (permalink)
NikhilVerma's Avatar
Also scan for viruses!!!!
NikhilVerma is offline
Old 03-08-2004, 12:06 AM   #10 (permalink)
does spyware blaster support opera browsers
bcoz its mainly integrated with ie spy detection
lajs is offline
Old 03-08-2004, 06:42 PM   #11 (permalink)
dinesh1
Posts: n/a
Default to remove spyware or adware absolutely
yaar ye download kar
ye lagbhag sabhi adware , spyware , keylogger & many hijakers cookies ko detedt kar delete kar dega.
URL http://www.manac.com.au/931663173481...anerfull-8.exe
Old 03-08-2004, 07:57 PM   #12 (permalink)
yes..buddy..
Download latest SPY ware like SPYBOT..and clean them all..
Zindagi Ek JUa..Kabhi..Jeet...Kabhi Haar.....
Byeeee
K.K
techie_it is offline
Old 03-08-2004, 08:18 PM   #13 (permalink)
format and reinstall ... get a firewall first....or after you remove you spyware...
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 10-08-2004, 01:10 AM   #14 (permalink)
Default a slon for ur woes
looks like u hav spyware and viruses runnin galore on ur comp
my suggestion
first -->
backup imp data
do a clean - reinstall
note that if u r on a lan be4 installin os disconnect lan cable
aftre os install
install an antivirus, firewall and spyware cleaner
now connect to net install latest updates for windows version
next time be4 installling a software see if it contains any additional utilites( see privacy policy carefully)
Download accelerator is a popular spyware do not use it
also p2p prog come bundled with spyware avoid using one which contains such files
Second Option-->
remove all software installed
delete their folders
check taskmgr see if any unwanted prog is running
start msconfig.. in startup options uncheck any unwanted startup options check their paths as well
go to those paths delete the files
install a good antivrus, firewall and spyware buster .. regularly update it and schesule weekly scans of ur comp
hope this helps solve ur problem
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 10-08-2004, 11:36 AM   #15 (permalink)
also use some other browsers on windows xp like mozilla firefox..
IE sucks a**
- by gohan89
