Old 30-03-2006, 10:11 PM   #1 (permalink)
saurabh.sauron's Avatar
Default Pinging Technorati
if u update ur blog, how do u inform technorati about it being updated?
in technorati, this information was there :-
Log in to your WordPress weblog.
Select "Options" from the top menu.
Select "Writing" from the sub-menu.
The last option on the page is "Update Services." Add Technorati's ping server as a new line within the Update Services text box.
http://rpc.technorati.com/rpc/ping
If Ping-o-Matic (http://rpc.pingomatic.com/) appears in the text box you are configured to ping Technorati as well as many other ping locations via a relay service. We recommend pinging Technorati directly with every new post and update.
but Update Services was not there. pls help
thnx
saurabh.sauron is offline
Old 30-03-2006, 10:45 PM   #2 (permalink)
champ_rock
champ_rock's Avatar
someone please tell the procedure for blogger also.....
Registered Linux user number 400618
champ_rock is offline
Old 30-03-2006, 10:55 PM   #3 (permalink)
siriusb's Avatar
Blogger by default pings weblog.com from which technorati gets after some time. But I prefer to ping technorati directly using my blog's ping url after I update my blog. As an example, my blog's url would be:
technorati.com/ping/http://myxp.blogspot.com?url=http%3A%2F%2Fmyxp.blogspot.com&ip=1
Winchester 3200+ @2,500MHz
siriusb is offline
Old 31-03-2006, 10:57 AM   #4 (permalink)
champ_rock
champ_rock's Avatar
do i need to just add this to the template? or somewhere else?
Old 31-03-2006, 11:59 AM   #5 (permalink)
siriusb's Avatar
No, this is supposed to be typed in the address bar. I don't type it everytime, of course, since it'll be in the auto-completed as soon as I type "te".
siriusb is offline
Old 31-03-2006, 10:58 PM   #6 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
If you add Pingomatic to your ping list, it will ping Technorati as well as many other servers for you ..
Pingomatic is active by default in WordPress ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 01-04-2006, 12:08 AM   #7 (permalink)
desertwind's Avatar
BTW, I was trying hardly to Claim my blog in technorati. I using WP in my own hosting. They deny the claim despite of repeated attempts. Any tips ?
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
- by gohan89
