Old 30-03-2006, 03:36 PM   #1 (permalink)
Dink2cool's Avatar
Default Sony dw-d120a dvd writer giving problems
Hi guys .. plz help me to solve this problem . the problem is that i bought a sony dw-d120a dvd writer today but it isn't writing any dvds . also the cd that i got with it had viruses so i had to install nero 6 . but nero 6 gives an error while writing and this way i've wasted 2 blank dvds . plz help me out
Dink2cool is offline
Old 30-03-2006, 04:34 PM   #2 (permalink)
Try Nero 7 or NTI CD/DVD maker
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 30-03-2006, 04:38 PM   #3 (permalink)
Dink2cool's Avatar
man as i said , the cd that i got had viruses ... so i can't install nero 7 .... and no one here has nero 7 ... is there any alternate way ???
Old 31-03-2006, 12:13 AM   #4 (permalink)
Hard to believe that a CD supplied with a Sony drive is containing viruses. Is it an OEM drive with copied software CD?
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 31-03-2006, 12:26 AM   #5 (permalink)
Dink2cool's Avatar
It doesn't seem to be pirated ...it looks like the real stuff ... but i too was surprised to see that it was affected by viruses
Old 31-03-2006, 01:53 AM   #6 (permalink)
try out a simple way of writing to DVD,through normal Xp copy and paste function.
Should work for u ... giving you the conclution that the drive is atleast working!
grinning_devil is offline
Old 31-03-2006, 06:14 AM   #7 (permalink)
nil_3's Avatar
Also try to change the media on which you are writing. I once faced similar problem.
nil_3 is offline
Old 31-03-2006, 08:18 AM   #8 (permalink)
How did you confirm that the CD contains viruses? Did you scan with more than one Antivirus?
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 31-03-2006, 11:25 PM   #9 (permalink)
Dink2cool's Avatar
no i scanned it with norton antivirus 2005 with latest virus definitions
- by gohan89
