Old 30-03-2006, 09:13 AM   #1 (permalink)
maharajadhiraj's Avatar
Default mp4 convertor
Know any software through which i can convert .mp4 files to .avi or any other video format
maharajadhiraj is offline
Old 30-03-2006, 10:45 AM   #2 (permalink)
parthbarot's Avatar
search on google and then find it..on...sites (full version) ok?
got it?
if u want sitenames of that kind then i can pm u..
regards,
Parth.
www.techlads.com
Paarth.
parthbarot is offline
Old 30-03-2006, 12:35 PM   #3 (permalink)
gxsaurav
Posts: n/a
The best & easiest way to do it is using Quicktime, however, other alternatives are there, like VirtualDUB
Old 31-03-2006, 03:10 PM   #4 (permalink)
I have already tried VirtualDUB. It does not support .mp4 files
Old 31-03-2006, 03:19 PM   #5 (permalink)
saurabh.sauron's Avatar
AVI/WMV MP4 Converter is ok..
saurabh.sauron is offline
Old 31-03-2006, 03:48 PM   #6 (permalink)
@saurabh
Can u tell me da EXACT name of the software. I googled it out & there were too many results. Cn u pls be more specific. Just name the software and i'll get it.
Old 31-03-2006, 04:02 PM   #7 (permalink)
The pWnster
Vyasram's Avatar
try power video converter. its easy and gives pretty good results
Sigs suck
Vyasram is offline
Old 31-03-2006, 04:52 PM   #8 (permalink)
@maharajadhiraj
AVI/WMV MP4 is the exact name..
Old 01-04-2006, 11:35 AM   #9 (permalink)
thanx saurabh. u hit the nail on the head when u suggested the software. thanx once again dude
shall also try out power video converter. thanx guys
Old 01-04-2006, 11:36 AM   #10 (permalink)
Old 01-04-2006, 05:44 PM   #11 (permalink)
!FREEWARES!
Akshay's Avatar
u can try blaze media pro: http://www.blazemp.com
This one can convert audio and video files from one format to any other format
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 02-04-2006, 03:34 AM   #12 (permalink)
mobilegeek's Avatar
Try Aim One Video Converter .. http://www.aimonesoft.com/video-converter.html
mobilegeek is offline
- by gohan89
