Old 29-03-2006, 08:27 PM   #1 (permalink)
Tech'ing life seriously!!
sude's Avatar
Default There are security hole/s in my PC
Hi diGit Forum users,
I have a PC having XP with SP2
and NOT HAVING ANY INTERNET CONNECTION.
recently i installed "SpyBot-Search and Destroy 1.4" and ran a scan. After the scan it showed me 5 Entries on "DSO Exploit". Clicking on the Entry it showed me the following details:
Company: Microsoft
Product: Internet Explorer
Threat: Security hole
Company URL:
http://www.microsoft.com/
Company product URL:
http://www.microsoft.com/windows/ie/
Company privacy URL:
http://www.microsoft.com/info/privacy.htm
Description
There's a security hole in IE allowing websites to execute code without asking you first. You can find more information at http://security.greymagic.com/adv/gm001-ie/
What should i do in order to "repair" current 'Security Holes' and future such problems. I have no internet connection at home. But still after couple of days after the previous scan again these 'DSO Exploit' appears. PLEASE HELP...
-SUDE
<>You will never gain out of nothing, so try something.<>
sude is offline
Old 29-03-2006, 11:25 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
what is the OS? If it is xp then use the autopatcher xp in the digit cds to install the necessary patches and updates.
Don't know about 98 though.
ilugd is offline
Old 30-03-2006, 08:31 AM   #3 (permalink)
::vicky::'s Avatar
i think u dont have sp2 if u r using xp then upgrade ur xp t sp2
::vicky:: is offline
Old 31-03-2006, 04:54 PM   #4 (permalink)
JGuru's Avatar
Better use Mozilla Firefox 1.5 with Adblock & script
blocking extensions and lot more.It's more secure
than IE and it loads faster.
JGuru is offline
Old 31-03-2006, 07:23 PM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
How can i test if my systems has any security holes? any website/tools available to do this?
Charan is online now
Old 31-03-2006, 10:28 PM   #6 (permalink)
Indian by heart
planetcall's Avatar
FF rules!! Why using IE. It is notorious for its holes.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
Old 02-04-2006, 06:06 PM   #7 (permalink)
sude's Avatar
[edited]
sude is offline
Old 02-04-2006, 06:35 PM   #8 (permalink)
Distinguished Member
anandk's Avatar
i think dso exploit was a problem which was solved aftr sp2. so jst chk if u have sp2. if u dont, best to install it and update with autropatcherxp.
to repair current security holes try these :
replace ur hosts file, with a 'good' hosts file,
add ie-spyads to ur restricted zone, etc...
here are some additional holes which you can plug up, to boost your
security & privacy, and reduce threats. use these preventive measures:
disable windows potentially annoying, built-in spam receiving
Messenger Services (not to be mixed up with msn msngr)
disable 'Universal Plug-n-Play", windows potentially exploitable
networking capability, which can expose your computer to internet
attacks.
disable the very powerful DCOM system, allows pieces of your computer
to be remotely activated across the Internet. (does not affext sp2 users)
it is always enabled in Windows systems by default. use the GRC DCOMbobulator.
freeware utilities assissting the above, and more, can be downloaded
from http://grc.com/freepopular.htm
u may like to disable several other of the other of these services:
MediaPlayer automatic updates, player identification. sending usage/
error reports to microsoft,
disabling ie6 authentication,
disabling officexp error reports,
disabling certain services,
disabling msn messenger,
disabling remote desktop/registry support
etc, etc.
all these and some more very interesting preventive measures & options
are availble in these excellent utilities
XP-AntiSpy
click http://xp-antispy.org/component/opti...ory/Itemid,26/
SafeXP
click http://www.theorica.net/safexp.htm
Xpy
click http://nsis.whyeye.org/
'The Computer Security Tool
http://www.computersecuritytool.com/
charangk : u can try system mechanic 6 or any of the above utilities
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 02-04-2006, 06:43 PM   #9 (permalink)
The pWnster
Vyasram's Avatar
yeah try to hack ur own system frm another system , if u succeed then, there is a security hole
Sigs suck
Vyasram is offline
Old 03-04-2006, 12:23 AM   #10 (permalink)
Rubik's Uncle!!
Charan's Avatar
Thanks a lot. you really opend my eyes. now from today onwards i will learn how to hack day and night with out sleep. and when i successfully learn to hack. then I will try to find if my system has any security holes from any other computer. after this i will hack the into the "Bugs Bunny's" Computers and change his name to "The most idotic moron in the world".
thanks
happy hacking.
Old 06-04-2006, 06:27 PM   #11 (permalink)
sude's Avatar
i have mentioned that i do have SP2 installed...
-SUDE
sude is offline
- by gohan89
