i have bought the foll compopnents.
ath. 3200+
asus a8n e mobo
vip ii22 cabby+300w smps
2*512 mb ddr 400 ram
nvidia 6600 128 mb. gfx.
now the components are not connected. and i need nyour help in connecting them as i am not experienced in it.
my first question:
while mounting yhe mobo on the cabinet,do i need to add insulation(i.e. the foam sheet they provide in the box beneath the mobo or anything else???)
because i read the manual,that the underside of mobo should not touch the cabby.
but i see somesmall metal dish under the slot for proccy.s suppose it is for conductig heat. or is it for something else????then addding insulation will interfere it wont it????
i9n my old p.c.,they have added insulation. .but in my new cabinet.the holes for screws are a little raused,while in the old one,they were not.
so do i the foam sheet beneath my mobo?????
