Old 28-03-2006, 02:46 PM   #1 (permalink)
Default Pen drive vs External Hdd
Hi ,
Does anyone know which is the best pendrive to buy (cost range also plz) and which is better is it pendrive or external Hdd which is the best ( cost range too)
Reply back asap
vln_0007 is offline
Old 28-03-2006, 03:02 PM   #2 (permalink)
tuxfan's Avatar
Pen Drive & External Hard Disk are quite different.
PD is more convenient to carry.
EHD stores more data.
Which of the two is more important to you, potability or storage?
Prices depend on the capacity which again depends on your need.
tuxfan is offline
Old 28-03-2006, 03:08 PM   #3 (permalink)
main is storage in that case which is the best to buy and it must be worth for the money (within 5000) and how much gb will in get in EHD
vln_0007 is offline
Old 28-03-2006, 03:25 PM   #4 (permalink)
You could buy a readymade external HDD but that would be really expensive. Best if you made one yourself.
Rs. 700 for an external enclosure.
and
Rs. 3300 for 120 GB HDD
Rs. 3700 for 160 GB HDD
Rs. 4100 for 200 GB HDD
drvarunmehta is offline
Old 28-03-2006, 03:36 PM   #5 (permalink)
so , i need to get a Internal HDD and then an external enclosure .combine both to get an USB enabled EHD
vln_0007 is offline
Old 28-03-2006, 08:29 PM   #6 (permalink)
Thats right.
Its no different from a readymade external HD except maybe a little less resistant to shocks. But the cost is significantly lower.
Old 16-04-2006, 11:30 PM   #7 (permalink)
jay4u's Avatar
external 40 gb seagate hdd plus casing = 3300 rs. and that too it fits in ur pocket easily...
Passwords are like underwear... Change them often...
jay4u is offline
Old 02-05-2006, 11:05 PM   #8 (permalink)
vignesh's Avatar
Default Re: Pen drive vs External Hdd
There was an article in the chip magazine some time back with the procedure of converting an HDD to a EHDD...
vignesh is offline
Old 02-05-2006, 11:39 PM   #9 (permalink)
abracadabra's Avatar
all of u take note all u guyz have metioned about the 3.5" drive. thiz culd be pretty bulky to carry around and wuld require an external power source sometimes. Instead go for a 2.5" laptop drives. Probably I guess this is not available in India. Check stores like NewEgg, Best Buy. As the 2.5" drives are easy to carry along. Else Check out the SUPERB offering from Western Digiatl's Passport Range. The are sleek and slides into your pants pockets. capacity ranges from 40 Gb - 120 Gb. Prices are a little stong. But worth the penny
abracadabra is offline
Old 03-05-2006, 09:34 PM   #10 (permalink)
hcp006sl's Avatar
Perfect idea. I've a PD of 1 GB (Transcend). Now I'm thinking of buying a laptop HD + external case. One of my friends has 40 GB HD and Transcend case. He also has a 512 MB PD. Well, if you can buy a 4 GB PD, then nothing else is required. Because, I think you will use it for transferring data from one computer to another. So, I also think you won't transfer 40/160 GB data at a time, 4 GB (=1 DVD) storage is enough. 8 GB PD is also available, but obviously costly. One thing you must agree PD is PD - nothing can be compared with it.
Product details:
http://www.transcendusa.com/products...l.asp?ModNo=90
http://ec.transcendusa.com/product/I...temID=TS8GJF2A
http://www.transcendusa.com/Products...l.asp?ModNo=89
Orkut members are invited to join:
http://www.orkut.com/Community.aspx?cmm=28705185
hcp006sl is offline
Old 04-05-2006, 06:59 AM   #11 (permalink)
q3_abhi's Avatar
Depends upon ur needs
For portability : Pen drives.
For storages : HDD.
U can get pen drives of 1 GB,2GB etc.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 04-05-2006, 09:25 AM   #12 (permalink)
gxsaurav
Posts: n/a
those of u who are going to buy an external harddisk & enclosure, i would say, that u buy a laptop HD with a 2.5" HD enclosure
not only this will run a lot cooler, it's very small compared to a 3.5" HD enclosure, also the power requirments are low, & the performance is really good also
Old 04-05-2006, 11:55 AM   #13 (permalink)
Learner
Kniwor's Avatar
i think 2.5" HDD is a good balance.......
it's cheap, it's reasonable small, and it's a monster
Kniwor is offline
Old 04-05-2006, 12:05 PM   #14 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
right said dude depends on ur need s if u wnt portabilaty go in fr a PD and if u can compromise portability an wnt more sapce go in fr a extrnl HDD...
PD :-
128(SONY)....Rs.1200(around)
256(SONY)....Rs.2400-2900
1GB(SONY)....Rs.5000and above(cough..)
dont know much bout ext HDD but u cn get one fr around 5K wid a cpapcity of bout 80 gigs (MAXTOR rules.....)
.....go fr the 1GB PD its more dn enough fr every one....
Ambar is offline
Old 04-05-2006, 07:14 PM   #15 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
I have 1GB kingston pen drive and I m happy with it. I use it damn roughly and it dont complain.
GO for Pen drive.
n00b forever...
~Phenom~ is offline
Old 04-05-2006, 11:28 PM   #16 (permalink)
hcp006sl's Avatar
PD :-
Then please opt for Transcend.
512 MB round about Rs. 1800 /-
1 GB ....................Rs. 2200/-
2 GB ....................Rs. 2800/-
4 GB ....................Rs. 3400/-
(8 GB probably not available in INDIA).
hcp006sl is offline
Old 05-05-2006, 12:33 PM   #17 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
DUDE transcend iz damn cheap got fr it
i trust sony fr itz reliability (had stripped it off itz body once..accidentaly...fixed it wid feviquick and voila itz working again.....)
Ambar is offline
Old 05-05-2006, 12:51 PM   #18 (permalink)
well do u know one drawback of pendrive??
u can lost it very very easily.....................many pen drives are being lost in cybercafes and offices as very few remember to take it out .
reddragon is offline
Old 08-05-2006, 09:48 AM   #19 (permalink)
Learner
Kniwor's Avatar
Drawback of pendrive...
it has limited Read/write.....
it is costly
small storage
Advantages of pendrive...
portability
Kniwor is offline
- by gohan89
