Old 13-07-2004, 10:38 AM   #1 (permalink)
Default Cannot partition hard disk. Help required
I have a 20 GB Quantum Fireball hard disk. I can not partition it at all. I have tried it using all the resources available with me like, Fdisk, Partition Magic, Partition Manager, Disk Druid (linux), Computer Management in WinXP. Every time I get some message that says "CANNOT PARTITION THE DISK". The HDD is detected without any problem in the BIOS. It is even detected by windows, I can even see two existing partitions in the explorer but I cannot use or change them. Is there any way out or should I forget it
jnpandya is offline
Old 13-07-2004, 12:14 PM   #2 (permalink)
tuxfan's Avatar
Have you tried a low level format of your hard disk? A low level format will remove all the existing partitions. Then you can start afresh.
You require some software that will let you do a low level partition. if you don't have any such software, I can send it to you by email. Its a very small software. You need to keep it on a DOS bootable floppy/CD and use it. It is called ZTEST (132 KB)
tuxfan is offline
Old 13-07-2004, 03:21 PM   #3 (permalink)
Ya sure, I'll be thankful to you if could send it to me. My e-mail ID is jnpandya@mail.com
I am trying to download it if possible, but please send it if you can.
jnpandya is offline
Old 13-07-2004, 03:34 PM   #4 (permalink)
I've already tried ZeroFill available on www.quantum.com but it doesn't help too...
jnpandya is offline
Old 14-07-2004, 10:45 PM   #5 (permalink)
avoid a low level format, it may destroy your disk, get professional help instead if you wish to recover data, or use rstudio fat/ntfs and get your data out and then try out all this shi.-.t
^ I wrote this!
akshayc is offline
Old 15-07-2004, 12:05 PM   #6 (permalink)
tuxfan's Avatar
I have done a low level format at least 5-6 times on my Samsung 40GB Hard Disk. It hasn't been deteriorated in any way!! Actually a low level format only removes all the partitions and FAT/NTFS/EXT2/EXT3 along with it. It doesn't touch the entire hard disk. The data is still there on the hard disk but it only become inaccessible. It can still be recovered with recovery software.
I have already send the file by email. However, since some apprehension is shown here, I would add here that you use the software at your own risk. However, I have personally used it and nothing has happened to my hard disk and it is working great.
tuxfan is offline
Old 15-07-2004, 05:56 PM   #7 (permalink)
Sinnet's Avatar
lol
low level formats dont destroy a HDD
dun worry
go for a low level format m8
but dont make it a habit
it does affect a HDD's life on long term
enjoy
sInNeT
Intel Core 2 Quad Q6600, 2GB Transcend DDR-II 667, Hitachi 320GB + 250GB SATA II, Sapphire ATI Radeon HD2600XT, ASUS P5B-Deluxe WiFi AP, Logitech G15, Philips 201B4......
Sinnet is offline
Old 16-07-2004, 07:26 PM   #8 (permalink)
You can also try sea-gates utility BOOT disk. It works with all & can be used to perform a low level format on your disk. It can even write zero to the entire disk if u wanna make it look like new!! .
Its a usefull soft even I use it when all other fails..
I will try and inc the link soon
To all the Mumbaikars
www.vtalk2.com
siddharth_menon is offline
Old 23-07-2004, 07:33 PM   #9 (permalink)
The Photoshop Guy
cooljeba's Avatar
Hmm.. i have never tried a low level format. R u sure u want to do i mean.
Back up ur data. I don't think it should damage the HDD 'cause then why is this option given .
..:: peace ::..
jeba
cooljeba is offline
Old 24-07-2004, 12:48 PM   #10 (permalink)
tuxfan's Avatar
Presence of Low Level Formatting softwares doesn't mean they don't damage. However, I haven't so far heard from any one that a low level format damaged his HD. It hasn't damaged even my HD. So I safely assume that it is not bad. However as someone said it here, don't make it a habit and it could be damaging if done too many times.
tuxfan is offline
Old 29-07-2004, 06:43 PM   #11 (permalink)
I've tried all the ways except the seagate boot disk option. I don't have that disk. But still the problem is unsolved.
jnpandya is offline
Old 30-07-2004, 10:54 AM   #12 (permalink)
tuxfan's Avatar
Have you tried the low level formatting with a bootable CD?
tuxfan is offline
Old 30-07-2004, 04:51 PM   #13 (permalink)
If I create a bootable CD using say Nero. How will I get access to a command for low-level format? I think I can only format the disk.
FDISK does not help at all. Every thing goes ok. The moment I restart the pc, things are as they were before using FDISK. I tried to use SEATOOLS (downloaded the image file for bootable CD) but it detects lots of errors in the partition table and then stops. It only diagnoses the problem and does not solve it.
I am not at all bothered about data on the hard disk as I have already taken important data long back. I want my 20 GB space, that's it.
jnpandya is offline
Old 30-07-2004, 05:05 PM   #14 (permalink)
The Photoshop Guy
cooljeba's Avatar
Hmmm... w8ting for the DVD there is a free dos gotta check it out may be that will help u .
..:: peace ::..
Jeba
cooljeba is offline
Old 31-07-2004, 11:37 AM   #15 (permalink)
tuxfan's Avatar
You have to create a bootable CD from an image of a bootable floppy. Keep the file used for low level formatting and FDISK along with some other necessary files on the floppy before you give it to nero for taking a boot image.
tuxfan is offline
Old 04-08-2004, 04:03 PM   #16 (permalink)
Tux Fan
shaunak's Avatar
u could try samsungs clear hdd to do low lvl formating.
www.samsung.com/Products/ HardDiskDrive/utilities/clearhdd.htm
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
- by gohan89
