Old 26-03-2006, 09:47 PM   #1 (permalink)
Default A Great Looking Powerfull Website
I have planned to design a great looking power full webpage by myself...
I want to know the list of all applications from basic level to high level web designing and the details about that(Use of that appli...).
Also please help me by giving some usefull tips and advices in creating webpage .
Regards...
navino87 is offline
Old 26-03-2006, 10:56 PM   #2 (permalink)
String Phreak
mediator's Avatar
Macromedia DREAMWEAVER -> for complete web page
Macromedia FLASHWORKS -> for some innovation if u really want a hardcore website!
editplus -> for quick editing of webpages,phps etc!
I think thats all u need!
mediator is offline
Old 27-03-2006, 08:44 AM   #3 (permalink)
How can you miss Adobe Photoshop?
the best tip, is keep it clean (organised) and fast loading, better if you post good content too!
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 27-03-2006, 01:24 PM   #4 (permalink)
Thank to thecyclone2k & mediator......
Is there any other applications or advices ?
navino87 is offline
Old 27-03-2006, 03:25 PM   #5 (permalink)
yeah, add notepad also on the list.
Well, if you can tell what kind of site you are making and what's it subject, then, I can think of more.
Old 27-03-2006, 06:24 PM   #6 (permalink)
hafees's Avatar
use table less XHTML + CSS design. And use AJAX where ever possible(but not to load entire page). AJAX scripts are available for free. search google.
hafees is offline
Old 27-03-2006, 06:44 PM   #7 (permalink)
hey hafees u talked something abt tableless !!!
is it possible in html through dreamweaver but widout using layers !!!!
gycapri is offline
Old 28-03-2006, 11:38 AM   #8 (permalink)
You can use "WebPage Maker" also.
alanpaladka is offline
Old 28-03-2006, 12:40 PM   #9 (permalink)
siriusb's Avatar
@gycapri,
yea tableless design is possible with html tags and a bit of css. Dreamweaver does support both of them.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 28-03-2006, 05:43 PM   #10 (permalink)
TechTin.com
ravi_9793's Avatar
yes...web page maer is a great wen page making toool...must try atleast once...download from trial version from its website...also it was given in any digit cd/dvd.It is really very easy...and it support drag and drop.
I have made my site using this... http://www.ravi.cjb.cc
ravi_9793 is offline
Old 29-03-2006, 11:15 PM   #11 (permalink)
Pharmaguru
kjuvale's Avatar
i have used ms frontpage 2003. great tool . very easy to use. ihave tried to build website. please taake alook at www.pharmatalk.coz.in
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
Old 29-03-2006, 11:55 PM   #12 (permalink)
Commander in Chief
QwertyManiac's Avatar
@ravi - there are lots of typographical mistakes on yr site, better fix them for a good look.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 31-03-2006, 08:30 AM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
hey..plz tell me hw can I improve the look of my website.
I will be thankful to u for ur good suggestion.
my website add is http://www.ravi.cjb.cc
Old 31-03-2006, 11:11 AM   #14 (permalink)
Beware of the innocent
ilugd's Avatar
Try tweaking the color combination a bit. The overall green and the blue for the navigation bar do not match. Try Dark Green for the Navigation bar with the links in white. The logo (photo) could also be a bit darker.
Another idea would be change the layout of the categories. It looks too cluttered to read clearly. I am talking about the banners.
BTW there seem to be some illegal stuff over there. Just take care.
ilugd is offline
Old 01-04-2006, 10:45 PM   #15 (permalink)
william's Avatar
there are numerous applicationd that can help u to design ur web page . like html tool kit and html editior . also make use of java if you can.
william is offline
Old 02-04-2006, 10:17 AM   #16 (permalink)
Gracias Senor
dreams's Avatar
In my experience Dreamweaver is the best.. i use it for all purposes whether for html or css..
its gr8 s/w..
and for images i use none other than Adobe Photoshop..
These 2 make magic in the web when used wisely..
happy designin..
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 04-04-2006, 12:03 AM   #17 (permalink)
ilugd's Avatar
GIMP and NVU. They are more than capable of standing their ground before dreamweaver and photoshop.
(No offence)
ilugd is offline
Old 04-04-2006, 12:15 AM   #18 (permalink)
Rubik's Uncle!!
Charan's Avatar
did u use a template? cause i had seen this one in a templates site.
BTW a very good looking site dude.
Charan is online now
Old 05-04-2006, 08:28 PM   #19 (permalink)
Pharmaguru
kjuvale's Avatar
yes I ahve used template it was avilable fior free. I used it as , i am a Pharmacy student and dont know much about html and just used phpbb for the forum. and yes thanks for yuor words.
kjuvale is offline
Old 06-04-2006, 12:51 AM   #20 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ I also used templates recently. I used it cause i wanted to know different layout styles possible to make my site. Once you get used to creating pages using templates you can build your own from scratch.
Old 07-04-2006, 10:27 AM   #21 (permalink)
Try out Trendy Flash Website maker...
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 08-04-2006, 06:06 PM   #22 (permalink)
ilugd's Avatar
what??
ilugd is offline
Old 09-04-2006, 02:52 PM   #23 (permalink)
i've recently uploaded my incomplete site,for making my site more attractive pls see n give suggestions
www.gmastermind.moved.in
gycapri is offline
Old 09-04-2006, 03:21 PM   #24 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^ dude there is a link www.digit.com in your site.it must be www.thinkdigit.com i guess :roll:
- by gohan89
