Old 26-03-2006, 02:55 PM   #1 (permalink)
Default Where to start a blog?
Can anyone give me a list of free sites to start a blog (similar to blogger.com)?
vinayasurya is offline
Old 26-03-2006, 03:05 PM   #2 (permalink)
Wandering in the zone ...
manas's Avatar
Wordpress.com
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
Old 26-03-2006, 03:35 PM   #3 (permalink)
saurabh.sauron's Avatar
http://typepad.com
http://www.theblog.cc
saurabh.sauron is offline
Old 26-03-2006, 03:53 PM   #4 (permalink)
busyanuj's Avatar
Blogger would be fine to start blogging.
Wordpress is another good blogging site.
busyanuj is offline
Old 26-03-2006, 05:44 PM   #5 (permalink)
http://www.bingbox.com/
http://www.myspace.com
http://www.wordpress.com/
http://www.livejournal.com/
http://spaces.msn.com/Default.aspx
http://www.blogeasy.com/
http://www.blogspirit.com/en/index.php
http://www.blogthing.com/
http://www.blogster.com/
http://www.blogspot.com
are the ones I remember right now.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 26-03-2006, 05:46 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Wordpress looks very neat and professional
If u like editing I wud recommend Blogger, nothin beats it IMO
Harsh J
www.harshj.com
QwertyManiac is offline
Old 26-03-2006, 05:51 PM   #7 (permalink)
GaurishSharma.com
gary4gar's Avatar
go for BLOgger only
gary4gar is offline
Old 26-03-2006, 05:51 PM   #8 (permalink)
hafees's Avatar
Wordpress is good.
also check http://my.opera.com They're offering 300MB
hafees is offline
Old 27-03-2006, 01:03 PM   #9 (permalink)
t3h g04t
teknoPhobia's Avatar
also check
http://360.yahoo.com
technologically challenged.
teknoPhobia is offline
Old 27-03-2006, 01:20 PM   #10 (permalink)
chinmay's Avatar
As Anuj rightly suggested that 'Blogger' would be the right place to start with blogging if you are new to it. Though, Wordpress has much better features, interface and customizability you might find it difficult to use in the beginning which may result in your lose of interest in blogging. The best part being latest version of Wordpress supports the importing of your content from Blogger so you won't have to worry about losing your data while shifting.
What I'd personally suggest is to go to Wordpress.com, get a blog and try using it. If you are comfortable, well and good. But if you find it difficult go to blogger, look around, get familiar and post a few blogposts. Later if you find blogging is your type of stuff and you spend more time blogging around than any other activity on the Internet you might want to buy some webspace and a domain and manually install a much more customizable blogging software, Wordpress from www.wordpress.org.
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
- by gohan89
