Old 05-11-2004, 02:33 PM   #1 (permalink)
Default problem installing LexmarkZ605 on XP...
Hi Guys,
I've got windows XP with AMD Athlon XP 1700+ which runs at 1.47Ghz with 376Mb RAM.
I've got Lexmark Z605 inkjet printer(USB Printer) and facing lot of trouble installing it.
OS detects the printers but its not showing up in printers and i'am not able to print any documents.
Please HELP
guarav_gupta is offline
Old 05-11-2004, 03:02 PM   #2 (permalink)
First...what problems are you facing ? do you still have the CD that must have come along with ur printer for it will contain the req drivers. If you dont have then here is a link to download the drivers.
http://downloads.lexmark.com/cgi-per...me=&fileID=556
Also check ur USB ports on ur motherboard and make sure they are working first :
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 05-11-2004, 04:02 PM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. Please elaborate .. "OS detects the modem but its not showing in printers" .. What do you mean by that ...?
Are you sure you have installed USB drivers for your motherboard ..?
Well.. you can get the updated drivers for you printer here :
http://downloads.lexmark.com/cgi-per...04:1:0:389:0:0
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 14-11-2004, 03:16 AM   #4 (permalink)
The problem i'm facing is The Operating systems detects a USB device connected .... and when i run the Lexmark CD and points to the USB driver on the CD for Lexmark ..... nothing happens .....
When i try to run the setup from the CD ... it finishes succesfully with the wizard but still cannot find the printer under Printers folder and cannot print anything.....
Useful Info1: While installing the driver 1st time .... it gave error "Cannot install the spooling software"
Useful Info2: Sometimes when i keep on trying to installing the software it talks about some certifications with microsoft.
That's it. I'm still not able to install and use the printer.
Old 14-11-2004, 09:17 AM   #5 (permalink)
vysakh's Avatar
r u trying to say that ur OS detects the printer but u cannot install the driver..
if yes try this
go to device manager and find printer. in the printer right click and select update driver. a menu will come asking which one to install. select the option dont search, i will give the driver. click next. then in the window click have disk. browse to the cd and select the driver and click ok
Incompatible message format
vysakh is offline
- by gohan89
