Old 25-03-2006, 11:32 PM   #1 (permalink)
Default how to change hardware id of a computer
certain software show hardware id of a computer . how to change it
bkpeerless is offline
Old 25-03-2006, 11:37 PM   #2 (permalink)
I don't think changing hardware id is legal... You may want to confirm that it is legal before trying to do so....
Cheers...
yashved is offline
Old 26-03-2006, 12:50 AM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
microsoft winxp generates the hardware id you refer to, i think. It uses a lot of details about your system configuration and it is so designed that it is a unique number, that means that no two systems in the world can have the same one. Though i am not too knowledgeable about it. It must be in the registry somewhere. There is a registry guru on the forum, (vishal) maybe he will have a look.
ilugd is offline
Old 26-03-2006, 12:54 AM   #4 (permalink)
ilugd's Avatar
Just a short note, i got this article thro google. It is quite long, so i am just posting a link
http://www.oreilly.com/catalog/winxp...pter/ch04.html
<edit-append>
Also check out this link for an idea for a workaround. Use your own judgement
http://www.pcbuyerbeware.co.uk/ProductActivation.htm
ilugd is offline
Old 26-03-2006, 01:21 AM   #5 (permalink)
u can change wit TweakXP Pro v4.0.6
Chindi_Chor is offline
Old 26-03-2006, 01:24 AM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
http://www.nthelp.com/NT6/change_mac_w2k.htm
now hardware besically means the NIC adapter ID... which can be change... just follow guide avobe....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-03-2006, 09:28 AM   #7 (permalink)
NO man..
he want change the Whole SysteM hard Ware Info..
Old 26-03-2006, 12:49 PM   #8 (permalink)
The Frozen Nova
casanova's Avatar
if u install some additional h/w or remove some h/w it changes automatically. Also, every time u reinstall ur OS, a new h/w id is generated.
www.nerdweed.blogspot.com
casanova is offline
- by gohan89
