Old 24-03-2006, 09:42 PM   #1 (permalink)
Are we there yet?
amrit1's Avatar
Default changing IP address!!!!!!!
Can anybody please tell me that How to change IP address?????
amrit1 is offline
Old 24-03-2006, 10:00 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Private IP or public IP? Are you in a LAN?
kalpik is offline
Old 24-03-2006, 10:06 PM   #3 (permalink)
Which ISP ? do u use ???
Chindi_Chor is offline
Old 24-03-2006, 10:56 PM   #4 (permalink)
most probably u'll be using dynamic IP address,in that case go to this site ..
www.whatismyip.com
grinning_devil is offline
Old 24-03-2006, 11:30 PM   #5 (permalink)
Your Maker.
MysticHalo's Avatar
That site just points out the IP address, that all......
I dont think u can change ur IP address at will, u will have to change ur ISP or ask ur current ISP to renew ur IP address
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 24-03-2006, 11:38 PM   #6 (permalink)
nishant_nms's Avatar
If ur ISP is providing an dynamic IP u cannot change ur IP. But if ur ISP offers a static one u can sak them and u can get ur IP change
nishant_nms is offline
Old 24-03-2006, 11:41 PM   #7 (permalink)
yes....
Old 24-03-2006, 11:42 PM   #8 (permalink)
exactly...the site is to check the IP of your machine.
in case its dynamic you can change it (infact its just refreshing,so it all depends on your DNS server if you'll be getting the same IP again or a diff one in a definate range)
ipconfig /release
ipconfig /renew
Old 25-03-2006, 11:17 AM   #9 (permalink)
Are we there yet?
amrit1's Avatar
i have bsnl broadband connection.
speed-256kbps.
it has dynamic ip address
amrit1 is offline
Old 25-03-2006, 11:36 AM   #10 (permalink)
Your Maker.
MysticHalo's Avatar
speed-256kbps.
BTW, could u plz point out the need for u to change ur IP address?
Yeah, devil has pointed it out correctly. Try this-:
http://www.daniweb.com/techtalkforums/thread36478.html
Old 26-03-2006, 12:32 AM   #11 (permalink)
you can use one software 'Hide IP' (search it).
I use it when i download stuff from portals like Megaupload or rapidshare.
Megaupload says that ur country(india) has cross the limit for maximum downloads, come again.
and rapidshare restrict download after some download size.
This software changes my IP address which also changes my country for portals. This is called proxy changing.
But this creates problem when I see non-english characters on website according to country set by Hide Ip.
amitgg is offline
Old 26-03-2006, 01:18 AM   #12 (permalink)
Rebooting
Choto Cheeta's Avatar
the best i feel is,
Tor: An anonymous Internet communication system
hard to configure if u r noob... but check their documentation section... that may help out.... but this one really rooks...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-03-2006, 09:06 AM   #13 (permalink)
You can use the following sites for anonymous browsing with no configurations -
http://www.unipeak.com/
http://www.anonymouse.org/
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
- by gohan89
