Old 24-03-2006, 07:05 PM   #1 (permalink)
Default infected by look2me adware
my pc is infected by look2me adware, flash animations, popups keep appearing, i have tried every software available in net but none of them helped me. i have tried following softwares, webroot spysweeper, adaware SE, spybotSand D, microsoft antispyware, norton antivirus, mcafee antivirus and antispyware,norton look2me removal tool
although every software detects it but none of them is able 2 remove it, they remove it temporarily but after restarting it appears again, webroot is somewhat effective as it stops the popups but adware is still there?
pls help me, is formatting is the only option??
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 24-03-2006, 07:29 PM   #2 (permalink)
try this link
http://www.pchell.com/support/look2me.shtml
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 24-03-2006, 07:57 PM   #3 (permalink)
no it is not working, tried the automatic method it says look2me not detected in r pc and i also tried manual method, the registries entries which they r asking me 2 delete is not present in my registry
thnx 4 help
paul_007 is offline
Old 25-03-2006, 12:31 AM   #4 (permalink)
Try googling for the help , you will get a lot of sites .
mako_123 is offline
Old 25-03-2006, 01:32 AM   #5 (permalink)
format your PC....backup your data and format it..
since you have tried almost all of the known spyware detection tools,and they are unable to remove it.you can though try hijackthis
grinning_devil is offline
Old 25-03-2006, 02:17 AM   #6 (permalink)
18 Till I Die............
Have you tried running the anti-spwares in safe mode? It has worked in the past for me.
http://www.bash.org/?258908
mehulved is offline
Old 25-03-2006, 08:55 AM   #7 (permalink)
install windowz Again...
Chindi_Chor is offline
Old 25-03-2006, 09:51 AM   #8 (permalink)
Distinguished Member
anandk's Avatar
do this. run ur ant-spys in safe mode, or schedule boot-time scans, ver posbl.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-03-2006, 03:15 PM   #9 (permalink)
OK i'll try in safe mode
paul_007 is offline
Old 25-03-2006, 05:26 PM   #10 (permalink)
yeah this has worked quite a lot
but popups still appear but very rarely , once in every 2 hours
thnx everyone
paul_007 is offline
Old 25-03-2006, 05:46 PM   #11 (permalink)
Still that is not good enough. Have you tried out different anti-spywares or just one? If not, do a thorough scan with different anti-spywares and check out the results.
If this fails too, you can run hijackthis and post the results onwww.hijackthis.de for analysis. And remove the malware detected.
mehulved is offline
Old 25-03-2006, 05:56 PM   #12 (permalink)
__Virus__'s Avatar
thnx everyone
naaaah still not guud....scan in safe mode again and probably post ur hijackthis log so that someone can analyze and help u out.
__Virus__ is offline
Old 25-03-2006, 06:49 PM   #13 (permalink)
Wandering in time...
Ankur Gupta's Avatar
well the best thing is to format ur pc and install windows again if the adware is not being removed by the antivirus or anti-adware software.
and remember to backup!
Ankur Gupta is offline
Old 25-03-2006, 09:59 PM   #14 (permalink)
here is my hijack log
Logfile of HijackThis v1.99.1
Scan saved at 9:58:32 PM, on 3/25/2006
Platform: Windows XP (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2600.0000)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\Program Files\TuneUp Utilities 2006\WinStylerThemeSvc.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\System32\Hummbird\inetd32.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Sify Broadband\BBImpSec.exe
C:\Program Files\Sify Broadband\BBClient.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\WINDOWS\system32\rundll32.exe
D:\softwares\HijackThis.exe
C:\PROGRA~1\MOZILL~1\FIREFOX.EXE
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://searchbar.findthewebsiteyouneed.com
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.sify.com
F2 - REG:system.ini: UserInit=userinit.exe
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\system32\msdxm.ocx
O3 - Toolbar: &Save Flash - {4064EA35-578D-4073-A834-C96D82CBCF40} - C:\Program Files\Save Flash\SaveFlash.dll
O3 - Toolbar: (no name) - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - (no file)
O4 - HKLM\..\Run: [SpySweeper] "C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe" /startintray
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKCU\..\Run: [SifyBB] C:\Program Files\Sify Broadband\BBImpSec.exe
O8 - Extra context menu item: Download All by FlashGet - C:\Program Files\FlashGet\jc_all.htm
O8 - Extra context menu item: Download All Links with IDM - C:\Program Files\Internet Download Manager\IEGetAll.htm
O8 - Extra context menu item: Download using FlashGet - C:\Program Files\FlashGet\jc_link.htm
O8 - Extra context menu item: Download with GetRight - C:\Program Files\GetRight\GRdownload.htm
O8 - Extra context menu item: Download with IDM - C:\Program Files\Internet Download Manager\IEExt.htm
O8 - Extra context menu item: Download with NetPumper - C:\Program Files\NetPumper\AddUrl.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Open with GetRight Browser - C:\Program Files\GetRight\GRbrowse.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\System32\msjava.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\System32\msjava.dll
O9 - Extra button: Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\WINDOWS\System32\shdocvw.dll
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\WINDOWS\System32\shdocvw.dll
O9 - Extra button: FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\PROGRA~1\FLASHGET\flashget.exe
O9 - Extra 'Tools' menuitem: &FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\PROGRA~1\FLASHGET\flashget.exe
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O10 - Unknown file in Winsock LSP: c:\windows\system32\idmmbc.dll
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} - C:\Program Files\Yahoo!\Common\yinsthelper.dll
O17 - HKLM\System\CCS\Services\Tcpip\..\{548F1E1C-2F42-4AFF-966A-ABD5E203F2F5}: NameServer = 202.144.50.4,202.144.13.50
O20 - Winlogon Notify: BITS - C:\WINDOWS\system32\m2julc191f.dll
O20 - Winlogon Notify: WRNotifier - C:\WINDOWS\SYSTEM32\WRLogonNTF.dll
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: Autodesk Licensing Service - Autodesk, Inc. - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: Hummingbird Inetd (HCLInetd) - Hummingbird Communications Ltd. - C:\WINDOWS\System32\Hummbird\inetd32.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Webroot Spy Sweeper Engine (svcWRSSSDK) - Webroot Software, Inc. - C:\Program Files\Webroot\Spy Sweeper\WRSSSDK.exe
O23 - Service: TuneUp WinStyler Theme Service (TUWinStylerThemeSvc) - TuneUp Software GmbH - C:\Program Files\TuneUp Utilities 2006\WinStylerThemeSvc.exe
paul_007 is offline
Old 25-03-2006, 10:17 PM   #15 (permalink)
Commander in Chief
QwertyManiac's Avatar
Remove NetPumper from yr sis and for best results use only one D/l-Manager
and perhaps these too...
W8 for more hlp
Harsh J
www.harshj.com
QwertyManiac is offline
Old 26-03-2006, 11:23 AM   #16 (permalink)
anandk's Avatar
yes u need to remove the default search url : searchbar.
eif u use ms anti-spy, u can use it to restore all ie browsers default urls/pages, easily.
posting ur hijackthis logfile at www.hijackthis.de will give u a detailed analysis.
Microsoft® MVP
anandk is offline
Old 26-03-2006, 11:27 AM   #17 (permalink)
hijack this is not able to remove these
it says use spybot to remove them and when i use spybot , although it removes them but after restarting these files appear again
paul_007 is offline
Old 26-03-2006, 06:39 PM   #18 (permalink)
anandk's Avatar
idmmbc.dll could b a legit file or a malware. it cud b a part of 'Internet Download Manager' software. Idmmbc.dll is the LSP DLL. so check its properties first. http://www.spywaredata.com/spyware/m...idmmbc.dll.php
if u feel ur winsock lsp has been damaged see this
http://www.download.com/LSP-Fix/3000...-10417025.html
schedule boottime scan of spybot and restart pc, and c what happens. there is such an option in spybots settings. hope 4 d best !
Microsoft® MVP
anandk is offline
Old 27-03-2006, 06:41 PM   #19 (permalink)
schedule boottime scan of spybot and restart pc, and c what happens. there is such an option in spybots settings. hope 4 d best ! Smile
thnx , thnx , thnx a lot finally this has worked 4 me
now no popups r appearing
the file idmmbc.dll was the cause and i removed it using winsock lsp fix but i think this was not a part of Internet Download Manager cause i am usin this since 4 months and it havnt creatd any problem 4 me, the problem started when i installed a software frm a warez site.
paul_007 is offline
- by gohan89
