what u could try is moving the uninstall file for a program (in the programs folder). then access the add/remove program and say remove program. Theoretically it shouldn't find the uninstall and say that the program might be gone, remove the icon. That way, the program should still be there, but invisible to the add/remove.
havn't tried this...but it makes sense
Nitin Garg...
