Old 23-03-2006, 09:03 PM   #1 (permalink)
Default How to Change The Drive NAme ?????
2day i Buyed New 200 GB SATA HDD..
i formated N Installed Media center 2005
My D Drive IS Showin.. DVD ROM
N I IS Showin.. Hard disk Drvie..
Chindi_Chor is offline
Old 23-03-2006, 09:09 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
You mean u wanna chage the drive letters right? Do it from disk management (right click my computer, select manage. You'l fine disk management there). Hust right click on the drive and select change drive letters and paths..
kalpik is offline
Old 23-03-2006, 09:09 PM   #3 (permalink)
dIgItaL_BrAt's Avatar
U can change the drive letter by using the Disk Management tool provided in XP (Control Panel-->Administrative Tools-->Computer Management)
dIgItaL_BrAt is offline
Old 23-03-2006, 09:43 PM   #4 (permalink)
tanxx for reply...
Old 23-03-2006, 10:35 PM   #5 (permalink)
No problem.
Old 23-03-2006, 11:28 PM   #6 (permalink)
i Wnt to keep E Name
But it is Not Dir ?? How to Write..
tanxx
Old 23-03-2006, 11:34 PM   #7 (permalink)
Beware of the innocent
ilugd's Avatar
the image in your original post and the one in the last post are not of the same system??? in the first there are CEFGHI
ilugd is offline
Old 23-03-2006, 11:39 PM   #8 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U hv to make the desired drive letter free, if u want to use it for other drive!
Regarding to the first pic, simply assign J to your DVD drive, then D: will be free, then u can assign D: to ur desired partition...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 23-03-2006, 11:59 PM   #9 (permalink)
I restrd the System ...The Drive Letter r Free
Now i added..
tanxxx
- by gohan89
