Old 22-03-2006, 11:30 PM   #1 (permalink)
Default My HDD is heating above 50 deg cel.Do i need to worry?
My HDD is heating above 50 deg cel..........sometimes it even reaches to 57 deg cel . .Do i need to worry? pls help
NagpurDaMunda is offline
Old 22-03-2006, 11:43 PM   #2 (permalink)
put ur mouse over the red bar where it says 50 degrees
it'll show u max temp of ur hdd ...
anyways since its in red. . im assuming its serious ...
i JUST installed hdd life myself so got to know some of its features
well anyways to the topic .. yeah .. get an hdd cooler / strategically place a fan near ur hdd
No Mercy, No Limits.
theraven is offline
Old 22-03-2006, 11:50 PM   #3 (permalink)
YES you need to worry. Get a hdd cooler and install it, this will increase the life / reliability of your hdd.
**** happens
pradeep_chauhan is offline
Old 23-03-2006, 12:29 AM   #4 (permalink)
after how much usage/data transfer ur getting this temp.?
because my HDD went above 50 just once when the transfer was close to 200GB,but after that it receded..and it stays in 40-45 range
@pradeep...man all of my PSU output cable are consumed by 2 optical drives,systrem fan,HDD etc.
any workaround for installing HDD cooler???
grinning_devil is offline
Old 23-03-2006, 12:30 AM   #5 (permalink)
String Phreak
mediator's Avatar
Clean ur cabinet first, and provide ventilation by installing some extra fan!
mediator is offline
Old 23-03-2006, 12:53 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
50's too high 40 -42 is quite ok for summers @ 35-36
Harsh J
www.harshj.com
QwertyManiac is offline
Old 25-03-2006, 11:41 PM   #7 (permalink)
::vicky::'s Avatar
open ur cabinet if possible work in a room where a/c is or atleast buy a small fan so that it can keep ur hd cool
well i idid one funny thing i applied the processors compound on hdd i mean on top of it not on circuits
and to my surprise earlier it had 35 c but after the temp was not more than 27 c
try it be careful not to aply on the seagate sticker or u will damage ur warranty
::vicky:: is offline
Old 26-03-2006, 07:29 AM   #8 (permalink)
@vicky ... thermal paste...has it dried up and formed a layer or is it still sticky ???
Old 26-03-2006, 12:33 PM   #9 (permalink)
Asterisk enthusiast
abhasbajpai's Avatar
just one thing
how this software mesures the temp of HDD
i mean where r the sensors for HDD located
and why the HDD manufactures are not providing these knida utlites
i mean every mother board manu is providing the same with there MB
i also D/L demo of this software but coudnt understand the working
my MB has seonsors (OI 865GBF and ita utility) but where are the sensors of HDD are located as samsung website is nt providing any information in this matter
abhasbajpai is offline
Old 26-03-2006, 12:59 PM   #10 (permalink)
gxsaurav
Posts: n/a
The sensor is in the ATA chipset of the harddisk, My HD stays at 36~40C in summer, & in really highusage, like copying files, DV copying it reaches 42~43, but never over 45
Old 26-03-2006, 04:51 PM   #11 (permalink)
I think you mean power supply to the cooler. If so, why not use a simple splitter, which is cheap.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 26-03-2006, 04:55 PM   #12 (permalink)
If it is correct, then the age of miracles is not over.
Somebody may explain how the thermal paste which is meant to transfer heat from one metallic surface to another can do such wonders to a HDD.
V.Prem Kmar
V.Prem Kumar
janitha is offline
Old 26-03-2006, 09:02 PM   #13 (permalink)
[quote="janitha"]
V.Prem Kmar
lol...dat was what i was thinking.. !!!
may be its between air and metallic surface ..
Old 26-03-2006, 09:48 PM   #14 (permalink)
mine nvr crosses 35c
Shwetanshu Srivastava
shwetanshu is offline
Old 26-03-2006, 10:39 PM   #15 (permalink)
i have two drives...
1. SATA 160GB - 45-47c
2. SATA 250GB - 49-52c
maybe it has something to do with PATA/SATA ??
Old 27-03-2006, 10:41 AM   #16 (permalink)
::vicky::'s Avatar
@grinning_devil it is still sticky not dried
and to all u people i dont know whether it is miracle or wht it is working for i guess i i discovered something new
hi hi hi
have fun brothers
Old 27-03-2006, 02:01 PM   #17 (permalink)
hi hi hi
have fun brothers
Why not we forum members make a nomination for Nobel price?('')
V.Prem Kumar
janitha is offline
Old 28-03-2006, 11:41 AM   #18 (permalink)
::vicky::'s Avatar
yeah great!!!!!!!!!!!!!!!!!!!
Old 28-03-2006, 08:13 PM   #19 (permalink)
Wandering in time...
Ankur Gupta's Avatar
well my seagate sata 160GB temp is around 44 degrees.
when i installed another system fan it dropped to 40 degrees.
so try installing another fan and c if it works.
Ankur Gupta is offline
- by gohan89
