what temperatures does ur intel active monitor show ?
of motherboard and processor ?
system zone 1 is the zone near the processor zone.
the system zone 2 is the zone where RAM is installed.i.e.
the dimmslots.
im guessin the msg that pops up is of intel active monitor ?
theres a new version of IAM available ... if u dun have it get it
if its a problem with the software it should be solved
actually im quite sure the problem is that ur system is gettin heated beyond ur threshold values ...
so just increase those values in IAM ..
but just in case ur components are really gettin over heated i asked u to post the temperatures ...
do plz do that before changin the threshold values ... as i wouldnt want u to fry ur components either
