Old 21-03-2006, 07:32 PM   #1 (permalink)
Default Problem with CD burning
I have SAmsung SW 240B cd writer and win xp pro sp2 and win 2000 as my operating system. 256 MB DDR RAM and 2.4 Ghz Intel P4.
Ever since I last burned 695 MB on a Sony 700 MB CDR disc my CD writer refuses to write more tha 500-510 MB on a single disk.
After that 695 MB on sony disc , i tried to write files from 4 folders (multisession disc using NERO 6.6.0.8) on to a mosaerbaer disc totalling (685MB) but that failed (got stuck at 515MB). I tried to write it on to another Mosaerbaer disc but that too failed. I changed my operating system to win 2000 sp4 and tried to burn the files again but that too failed . I tried that simulation but no error occurred during that.
When I clicked on continue multisession to write some other files on to a multisession disc (cdr was made a multisession disc before this incident, this CDR was mosaerbaer and I wrote 200MB on it).
I later burned an iso (bootable disc) whose size was 680 MB on a Sony disc using Clone CD on Win Xp , no error occurred. I thought that the mosaerbaer discs were at fault. yesterday when i tried to write some files whose size was 580 MB on to Sony disc the same problem occurred it got stuck at about 505 MB and 'invalid write state' was the error which was shown that time.
What is this problem related to??? What should I do??
I am putting the log which i saved yesterday.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 4:21:30 PM
Nero Version: 6.6.0.6
Recorder: <SAMSUNG CD-R/RW SW-240B> Version: R403 - HA 1 TA 1 - 6.6.0.6
Adapter driver: <atapi> HA 1
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST DVD-ROM GDR8163B>Version: 0L15 - HA 1 TA 0 - 6.6.0.6
=== Scsi-Device-Map ===
DiskPeripheral : ST320413A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8163B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-R/RW SW-240B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVD-ROM GDR8163 E: CDRom0
SAMSUNG CD-R/RW SW-240B F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 39845888 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 247MB (253424kB)
Free physical memory: 23MB (24432kB)
Memory in use : 90 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.3.2006
CD-ROM (ISO)
9:38:18 PM #1 Text 0 File Isodoc.cpp, Line 6168
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
9:38:19 PM #2 Text 0 File Burncd.cpp, Line 2870
JustLink activated
9:38:19 PM #3 Text 0 File Reader.cpp, Line 127
Reader running
9:38:19 PM #4 Text 0 File Writer.cpp, Line 122
Writer SAMSUNG CD-R/RW SW-240B running
9:38:19 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
9:38:21 PM #6 Text 0 File Burncd.cpp, Line 3155
Turn on Track-at-once, using CD-R/RW media
9:38:22 PM #7 Text 0 File DlgWaitCD.cpp, Line 257
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 299223 ( 66:31.48)
9:38:22 PM #8 Text 0 File DlgWaitCD.cpp, Line 269
Write in overburning mode: NO (enabled: CD)
9:38:22 PM #9 Text 0 File DlgWaitCD.cpp, Line 2311
Recorder: SAMSUNG CD-R/RW SW-240B;
CDR code: 00 97 24 16; OSJ entry from: SONY Corporation
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 18 10 (LI 97:24.16), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
9:38:22 PM #10 Text 0 File DlgWaitCD.cpp, Line 431
>>> Protocol of DlgWaitCD activities: <<<
9:38:22 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 829
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 299224 (299224) = #299224/66:29.49
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 299222 blocks [SAMSUNG CD-R/RW SW-240B]
9:38:22 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1042
Prepare recorder [SAMSUNG CD-R/RW SW-240B] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 613117952, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
299224 | lead-out | 1 | 0x41 | 0x00
9:38:22 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1110
Removed 2 run-out blocks from end of track 1. Length: 299224 -> 299222.
9:38:22 PM #14 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
9:39:15 PM #15 Text 0 File Burncd.cpp, Line 4042
Cache writing successful.
9:39:15 PM #16 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
9:39:15 PM #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 40x (6,000 KB/s)
9:39:15 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2604
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:39:15 PM #19 Text 0 File Mmc.cpp, Line 21079
Set BUFE: JustLink -> ON , JustSpeed : ON
9:41:56 PM #20 SCSI -1135 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03010000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x03 0xD1 0x40 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x03 0xC6 0xB6 0x0C
0x00 0x00 0x00 0x00 0x0C 0x00
9:41:56 PM #21 CDR -1135 File Writer.cpp, Line 311
Write error
9:41:56 PM #22 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
9:41:57 PM #23 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
9:42:17 PM #24 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
SAMSUNG CD-R/RW SW-240B\H1 T1
9:42:17 PM #25 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
9:42:17 PM #26 Text 0 File Mmc.cpp, Line 15779
<SAMSUNG CD-R/RW SW-240B > start Close Session
9:42:36 PM #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 40x (6,000 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 10:59:44 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
It is better to light a candle than to curse the darkness.
Shikhar is offline
Old 21-03-2006, 07:38 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Try burning at a lesser speed. I had a similar problem and when i then used to burn at 16x or something, it works out fine.
ilugd is offline
Old 21-03-2006, 08:11 PM   #3 (permalink)
digiFriend's Avatar
i had lots of problems with mosaerbaer cd when overburning or writting more than 600 mb. but with other media,like sony cd, etc i have burn 700mb without any error. so i don't prefered mosaerbaer.
digiFriend is offline
Old 22-03-2006, 04:51 PM   #4 (permalink)
I had 10 cd pack of mosaerbaer earlier but no problem occured during that time. But I don't know what has happenned to my cd drive that if start a multisession disc it does not write more than 510 MB for the first time. The remaining files have to be burnt then by continuing the multisession disc.
Shikhar is offline
Old 22-03-2006, 06:40 PM   #5 (permalink)
hafees's Avatar
Try this with another branded CD. Are you sure, you didnt change any settings? If you're not try re installing your cd burning software. (preferably after cleaning the registry)
hafees is offline
Old 22-03-2006, 07:34 PM   #6 (permalink)
let me note that samsung optical drives suck.
plz dont mistake me . but i had samsung riter too and it had all probs , now changed my PC.
neway . have tried copying CD's that are above the 650mb mark . , i. e . . try to copy and see if it works. this is test whether ur riter is able to rite cd's above 650mb atleast in DAO mode .
Also , u cud try a firmware upgrade.
Now rite ur experience.
sagargv is offline
Old 19-05-2007, 06:48 PM   #7 (permalink)
Default Re: Problem with CD burning
I was out for a year.
Now this problem has become more serious.
Whenever I try play a disc using my CD writer I hear a few beeps and my system hangs. This is happening in both the OS ( Win XP pro sp2 and win 2000 sp4) However all the discs can be easily played using my LG DVD drive.
Even when I start my pc I hear 2 beeps , exactly at this pt of time I see led of Samsung drive glow for a second (This is when the POST (power on self test) takes place.)
What to do now?
Shikhar is offline
Old 19-05-2007, 06:58 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
Woah u bumped up an year old thread... .. anyway it seems to be a hardware problem, Better replace the CD Writer
rebooting
ChotoCheeta.com
Choto Cheeta is offline
- by gohan89
