Old 20-03-2006, 12:31 PM   #1 (permalink)
The Researcher
Default using Ghost
Can anyone enlighten me on using Ghost. I have heard that one can use this to create images of our Hard Drive and use it in case of emergency. Please tell me how to use it
Ramakrishnan is offline
Old 20-03-2006, 01:51 PM   #2 (permalink)
if u have ghost soft. also norton ghost . u can use any.
Norton ghost easy to use
patelviren is offline
Old 20-03-2006, 02:18 PM   #3 (permalink)
hey do following
boot pc from bootable 98 cd
now run ghost.exe
next
select option as per ur need that is
Drive to img
partition to img
partition to partition
img to partition
but take care in selection wrong selection may cleanup ur partition or may copy ur one partition data to another
Old 20-03-2006, 03:29 PM   #4 (permalink)
The Researcher
Thank you. patelviren
Old 20-03-2006, 04:47 PM   #5 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
I have been using Ghost, Its good, when the system slowdown I just restore c: from back up. Reformat in just 5min.
with my new system .. The Ghost 8.0 wasnt working, So, I tried Acronis True Image 9.0 - this works even better.
rollcage is offline
Old 28-05-2006, 08:54 AM   #6 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Smile Re: using Ghost
Please everybody use NORTON GHOST 2003, it has always been the best version of ghost till now. Also the previous versions didn't support NTFS partitions. This version is truly amazing. its worth every penny.
techtronic is offline
Old 28-05-2006, 09:46 AM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: using Ghost
Here's a guide i wrote using Acronis True Image. http://kalpik.zeeblo.com/?p=30
kalpik is offline
Old 28-05-2006, 10:39 AM   #8 (permalink)
Is it possible to use Norton Ghost 2003 with Win XP in NTFS? I have the SW but never used it. Also if the OS crashes, is it possible to restore it with the image in a previously made Ghost image CD? I am having original XP CD. Also is it necessary to activate XP again after restoring using Ghost?
V.Prem Kumar
janitha is offline
Old 28-05-2006, 11:00 AM   #9 (permalink)
Distinguished Member
anandk's Avatar
'ghost' is one sw/utility i havnt tried...maybe i shud do so now...
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 28-05-2006, 12:14 PM   #10 (permalink)
kalpik's Avatar
Yes, you can use Ghost with NTFS and no, activation is not required again.
kalpik is offline
- by gohan89
