Old 17-03-2006, 08:34 PM   #1 (permalink)
Gunner's Avatar
Default Pop ups
I find that I get a lot ofpop-ups when I connect to the net. There weren't as many pop ups before I installed Limewire or Opera. But now, there seem to be way too many. I don't know if the problem I'm facing is dues to either of these programs, but if they are, is there a solution to it without having to delete either of the programs ?
Gunner is offline
Old 17-03-2006, 08:55 PM   #2 (permalink)
yrana2002's Avatar
Well, maybe these softwares installed some adware stuff on your pc which frequenlty collects information about your browsing & brings in the appropriate popups.
If you use firefox, you shouldn't be annoyed with the popups. If you are using Internet Explorer, you should install a popup blocker.
You can also run a scan for Adware programs using Ad-Aware or Spyware Doctor to remove these adware files.
Savvy
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 17-03-2006, 09:05 PM   #3 (permalink)
the best IE pop-up blocker that comes to mind is google toolbar(used it when i was with IE )
Also have a look at the add/remove programs list,if u find any programs that u have not installed and appear funny remove them..
also as yrana suggested...adaware and spybot..run them and u'll be amazed at the result!!
grinning_devil is offline
Old 18-03-2006, 01:17 AM   #4 (permalink)
Gunner's Avatar
Alrighty ! Thanks, but isn't there a way to install a program which will remove any spy or adwares attached to the PC ?
Gunner is offline
Old 18-03-2006, 07:00 AM   #5 (permalink)
thats what i told u about..
> adaware . >> www.lavasoftusa.com/software/adaware/
> spybot >> www.safer-networking.org/
Old 18-03-2006, 11:43 AM   #6 (permalink)
Beware of the innocent
ilugd's Avatar
Default Ie needs a popup blocker to be installed??
I sometimes use ie to access msdn and i noticed that it has a popup blocker inbuilt. But i guess i have winxp sp 2 and ie6. Maybe that is it??
Adaware and spybot sure do work like a charm
ilugd is offline
Old 18-03-2006, 12:46 PM   #7 (permalink)
Gunner's Avatar
Thank you very much.
Gunner is offline
Old 18-03-2006, 02:32 PM   #8 (permalink)
hafees's Avatar
Default Re: Pop ups
Opera is not a spyware. The latest Opera (9 beta) has one of the best pop up blocking facilities.
I recommend Spybot. also you should update the program(detection rules) regularly.
hafees is offline
- by gohan89
