Old 09-07-2004, 05:01 PM   #1 (permalink)
nipun_the_gr8
Posts: n/a
Default How can I record songs while listening to them online ?
Can any1 tell me how can i record the songs & save them as mp3'z while listening to them online & without a mic (if possible) usin' a software
Old 09-07-2004, 06:43 PM   #2 (permalink)
AskRajesh
rajeshjsl's Avatar
yes ofcourse.
play the song file using windows media player 9 and it will record it also and play it also . it will record till the time you play but you can quickly download also.
use realone also or jetaudio
rajeshjsl is offline
Old 10-07-2004, 09:56 PM   #3 (permalink)
hey y don't u try musicmatch jukebox!!
i have recorded many songs from FM!!
We are what and where we are because we have first imagined it...
--Donald Curtis
silly_kash is offline
Old 10-07-2004, 10:09 PM   #4 (permalink)
check the recorder option and choose the source in musicmatch jukebox.
u can record mp3's with it or convert ur cassestes into cd's
with mmj!!
--Donald Curtis
Old 10-07-2004, 11:49 PM   #5 (permalink)
VD17's Avatar
there are many good recorders... even Nero's Wave Editor does a very good job....
all you have to do is select Stereo Mix as the input option and start recording....
and in case what u want to record is played by a SITE's flash player or something, [i.e. NOT a streaming audio], then you can simply search the temporary internet files for that file in .swf format and copy it to another location... WMP plays flash files...
Vinayak
Dell XPS M1530: Intel C2D T5750, 4GB RAM, 250GB HDD, 256MB nVidia 8600GT GDDR3
Creative EP-630, Philips SHP 805.
VD17 is offline
Old 15-07-2004, 12:25 PM   #6 (permalink)
well if you use Xp u can use movie maker,record whatever is coming out of your speakers.if you don't try freecoder1.02,its free and its available in this months digit cd
skrbhatt is offline
Old 16-07-2004, 08:09 PM   #7 (permalink)
i am a bit confused here ....suppose i am listening to raaga.com which only uses real player as an option for playing the songs .....is it possible to record through some other software like nero wave editor or does it neccesarily hav to be played and recorded in the same player?
sabman is offline
Old 16-07-2004, 08:59 PM   #8 (permalink)
VD17's Avatar
yes u can record it with Wave Editor, etc....
Vinayak
VD17 is offline
Old 17-07-2004, 11:50 AM   #9 (permalink)
Thor's Avatar
This months digit carries an excellent Free recording software, -> Freecorder.
Keep it switched on in the background while u listed to online music and it will keep recording any sound passing through ur sound card.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 17-07-2004, 02:55 PM   #10 (permalink)
Yeah
Capturing streaming Audio or Video is a piece of cake.
amitsaudy is offline
Old 22-10-2004, 10:36 PM   #11 (permalink)
thanx guys .. for freecoder.. i earlierused mmj but this is a nice package without any hazzle and its free ! gr8 .. keep up the spirit thanx frens
Life is a game.....Play it to win.
visvo is offline
Old 23-10-2004, 12:59 AM   #12 (permalink)
swatkat's Avatar
The best software for recording is Audacity.It's a freeware and it can record sounds/music from ANY source i.e Mic,LineIn,Currently Playing music ,even Click sounds made by Windows.It can encode into many formats including Mp3.
http://swatrant.blogspot.com/
swatkat is offline
Old 23-10-2004, 02:39 AM   #13 (permalink)
Default my opinion...
I dont agree with swatcat......best is WINAMP 5.05 8)
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 23-10-2004, 11:12 AM   #14 (permalink)
Bewitched!
xenkatesh's Avatar
There are various tools to record Dude try googling and find one!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 15-11-2004, 09:23 AM   #15 (permalink)
Default For u all
Web Stream Recorder Pro is a program that allows you to save multimedia data streams coming from the Internet or LAN to your computer. It can record music, video, radio broadcasts and adult content. Having saved this data, you will be able to play them from your computer without connecting to the Internet. Web Stream Recorder Pro effectively solves 2 main problems that emerge when you attempt to save video/audio streams: intercepting the source address and saving the stream to the disk.
http://www.sytexis.com/bin/wsrecorderpro_1_0.exe
suhas_sm is offline
Old 15-11-2004, 12:37 PM   #16 (permalink)
nipun_the_gr8
Posts: n/a
Thankx d00ds !!
Old 16-11-2004, 12:50 AM   #17 (permalink)
Maverick340's Avatar
Can someone tell me in a detailed step procedure how to record a song ur listening on FM(indian FM please!!)
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 16-11-2004, 12:55 AM   #18 (permalink)
swatkat's Avatar
I think WinAmp can not record the music if it is being played in another player and it capable of recording only when it is being played by itself using DiskWriter plugin.If i am wrong correct me by replying here in this thread.
swatkat is offline
Old 16-11-2004, 01:01 AM   #19 (permalink)
swatkat's Avatar
You can do this using a software called Audacity.Select the Recording Source in Audacity as "Line In" and then connect the Head Phone Jack of ur FM Radio to the Line In of ur PC.Then click Record button in Audacity and then Play the music in FM Radio.
Keep in mind to set the BASS and TREBLE of ur Radio (if u have these controls) to MINIMUM position to decrease disturbance and also adjust Volume of the FM Radio so as to get optimaum clarity.By this u can get good results.But u have to some test recordings to get good clarity.
Download Audacity at:-
http://audacity.sourceforge.net/
swatkat is offline
- by gohan89
