On playing the VCD in ur VCD Player, do you get the regular screen or some customized software screen? If yes, this thing uses some protection (to avoid copying to a computer). Anyway try this.
search for the largest file. That should be the video.
Then try playing this using a good player like Power DVD or WinDVD or even VLC player. (most probably media player will produce some errors).
