Old 03-11-2004, 09:55 PM   #1 (permalink)
Default stree dvds problem
I purchased a dvd frm the rd of mumbai which had 5 movies in it , now it has a crack in it (physical crak)so i need to bak up all the movies which software will do the needful ,
Can the full dvd be replicated having same quality within one or 2 or 3 blank discs(cdS)
Is it necessary to rip it completely and then convert it into various formats or there is sum option to directly rip it in desired format or other vcd formats which occupy less space.
I know there r several similar topics in the forum but cudnt find it so threads wil also be help full.
Also wat is .vob ,is it video format and does it need .ifo.
[/code]
Never argue with an idiot ,first he will lower u till his level ,then beat u with his experience.
akitosforever is offline
Old 04-11-2004, 02:45 PM   #2 (permalink)
A CRACK ?
not even a SCRATCH ?
no drive will read a cracked dvd m8 as far as i know ...
however if it works
then there are topics u can easily find here
anyways first u need a ripper to rip those VOB files from the dvd ...
VOB's are to DVD's like MPG's are to VCD's
for thise use either smart ripper / dvd decrypter
now this will automatically select the longest file as the movie to be ripped ( usually each movie will have 2-3 VOB's in the case of these multicompilation discs )
rip the movie to a folder. .. again use the software ... select a diff movie and rip it to a diff folder
ull know what im talkin abt when u use the software ... it shows length of each "chapter" which will each be above 1.5 hours ofcourse .. so u know those are ur movie files
now with the VOB's in tact .... follow this
http://www.thinkdigit.com/forum/viewtopic.php?t=5338
now u have to follow these steps to make ur avi or vcd .... u have to go thru the step of saving the VOB's on ur HDD ...
cuz even if u do it directly ... those files are gonna get saved temporarily on ur hdd anyways
converting each movie will take 2 cds fr a VCD for english movies .. and 3 for hindi depending on the length of the movie ofcourse
the video quality will be good
its ur audio quality that'll suffer
specially since these dvd's already have low quality audio
anyways to make a 5.1 channel SVCD follow this
http://www.thinkdigit.com/forum/viewtopic.php?t=8806
No Mercy, No Limits.
theraven is offline
Old 04-11-2004, 11:09 PM   #3 (permalink)
Never put a cracked cd/dvd in a drive...The rpm at which it spins is enough to blow it to pieces. Btw, this happened to my friend. Anyway it's pirated..
DON\'T waste money on expensive ipods. Simply think of your favourite tune and hum it. If you want to \"switch tracks\", simply think of another song you like and hum that instead.
gamefreak14 is offline
Old 05-11-2004, 06:32 AM   #4 (permalink)
As gamefreak14 said, never put a cracked CD/DVD in a drive or it will self-destruct in some seconds.
Simple things are to simple too understand.
Prashray is offline
Old 05-11-2004, 08:27 AM   #5 (permalink)
ice
Umm, I doubt it will have vobs, its has friggin 5 movies in it. for all u know, the seller has just dumped 5 avis into it.
Btw, if it is cracked, how did ur pc read it?
ice
ice is offline
Old 05-11-2004, 03:16 PM   #6 (permalink)
no man it is very slight crack at the centre plastic part,any ways the movies are in the proper dvd format,and any more suggestion on my original querry
Old 05-11-2004, 03:23 PM   #7 (permalink)
the main querry is """Can the full dvd be replicated having same quality within one or 2 or 3 blank discs(cdS)
Is it necessary to rip it completely and then convert it into various formats or there is sum option to directly rip it in desired format or other vcd formats which occupy less space. """
Old 05-11-2004, 03:29 PM   #8 (permalink)
Old 05-11-2004, 05:47 PM   #9 (permalink)
JEESUSS CHRIST what are u ... blind ???
read my post clearly !!
@ice ... no dude .. they have vob's not avis
these dvd's work on normal dvd players
they use compressed ac3 for audio ... which makes a lot of diff
theraven is offline
Old 05-11-2004, 05:50 PM   #10 (permalink)
ice - No the movies are not in avi formats. I think I know which DVD he is talkin abt as well...I had the same...I wondered the same thing as to if they are just 5 AVI's they werent. And the best thing is my DVD player which is 3 years old played it all without a hitch...fancy that....
akit - IF you want to convert it to VCD try ur luck...doubt its gonna happen with a crack in the middle. And each movie has to be ripped but it can be directly ripped into a desired format such as mpg or avi thats ur issue. But quality will be lost when convered into a VCD. So since each of these movies will be above the designated 80 mins Its impossible to sutff the movie in one CD. so you will need 2 CD's per movie. Which is 10 CD's mate.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 05-11-2004, 07:11 PM   #11 (permalink)
mariner's Avatar
happened twice to me
mariner is offline
Old 09-11-2004, 08:20 PM   #12 (permalink)
DVD Decrypter can do the job for you. Put the DVD in the drive and DVD Decrypter can rip them.
If u have Nero Recode it can convert VOBs to MPEG2 files.
Then it depends on how u want to store them.
Also try dvd shrink but u may lose quality
kaysquare is offline
Old 09-11-2004, 10:29 PM   #13 (permalink)
Bewitched!
xenkatesh's Avatar
Try DR DIVX i think this will help u!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 10-11-2004, 12:36 AM   #14 (permalink)
swatkat's Avatar
You can get any software u want to conver dvd to any format u want at:-
http://www.dvd-ripper.biz/
http://swatrant.blogspot.com/
swatkat is offline
Old 10-11-2004, 12:59 AM   #15 (permalink)
I think the movies are just copies from pirated VCDs. no way you can fit 5 mpg2 movies in one DVD with 5.1 surround. even if they are DVD quality pictures the sound will be just stereo. i have seen lots of this crap.
mozozozo is offline
Old 10-11-2004, 03:19 PM   #16 (permalink)
@mozozozo are u blind ? or are u just playin stupid ?
READ FIRST BEFORE MAKIN ILLEGITIMATE COMMENTS
theraven is offline
Old 13-11-2004, 11:28 AM   #17 (permalink)
Default ***best dvd replication soft out there********
hey dude
try intervideo dvd copy 2 ,it makies superb quality vcd's from dvds .
mail me for more help.
startrek.ek@gmail.com 8)
kuttycool is offline
- by gohan89
