I have converted my FAT32 file system to NTFS by convert command.now i want to convert it back to FAT32 but it shows convert is not available for NTFS.How can i convert it back.i have windows xp.
You can use Partition Magic. It can convert NTFS to FAT32 but remember that it is also known as "Partition Tragic". So do backup your data before doing anything as drastic as changing from one file system type to another. imho you can try Partition Magic but the best way to do it will be to delete the partition and then format. Choice is yours.
as eddie said, it is very risk to convert fat32 to ntfs. The risk is even higher if you had password protected any of your directories, or used encryption etc. It will throw an error message in the middle and u can do nothing. So BE CAREFUL
__________________ Quitters Never Win & Winners Never Quit!
Actually i want to reinstall windows but it tells me that i need to format all my drives to reinstall windows.If only c drive i can understand but all the drives??
