Old 14-03-2006, 09:49 PM   #1 (permalink)
Default Sound is not coming in some movies
In my computer sound for some latest movies is not coming.. the movies are pirated copies of some films but if I take the harddisk to some other computer the same files are playing with sound.. Not all movies but only some are not playing sound but the movie is coming.. I cant find the problem..
Does any one help me?
robogeek is offline
Old 15-03-2006, 12:20 AM   #2 (permalink)
Dreaming is THE art...
Dreamer's Avatar
change the volume balance to left or right.
its happens to me too, & after changing the
balance, prob is solved 4 me.
Dreamer is offline
Old 15-03-2006, 12:48 AM   #3 (permalink)
El mooooo
eddie's Avatar
The most probable problem could be lack of AC3 codecs. Lots of movie files on internet use this codec. Install a codec pack like k-lite and it will provide all the required codecs for playing the movies.
eddie is offline
Old 18-03-2006, 11:40 PM   #4 (permalink)
Beware of the innocent
ilugd's Avatar
Try the BS Player bundled with K-lite or the VLC Player. But from your post it most probably seems a configuration problem in the system. Has the previous replies helped any??
ilugd is offline
Old 19-03-2006, 12:34 PM   #5 (permalink)
siriusb's Avatar
Try gspot. It will show what codecs the movie requires to run properly. Then you can google the codec and download it.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 22-03-2006, 07:02 PM   #6 (permalink)
hafees's Avatar
Install the KLite Mega Codec pack. It includes almost all codecs including quicktime and real
hafees is offline
