I am using Win XP SPII with all critical updates. In addition, I have Spybot, Spywareblaste, MS Antispy and Avast AV. Whenever I run Ad Aware it finds two critical security issues the details of one of which are shown below. The other one is similar. Even after removal, the next time I run the Ad Aware, the same two are found. BTW, other SW do not detect them.
Category:Vulnerability
Object Type:RegData
Location:regfile\shell\open\command "" (notepad.exe %1)
Last Activity:14-03-2006
Relevance:Low
TAC index:3
Comment:
Description:General Windows Security Issue. Your system security may be compromised. The specifics of the possible compromised item are listed in the comments section.
Pl tell me what does it mean and what is the solution.
V.Prem Kumar
